Old 02-01-2017, 10:07 PM   #1
ejaf
Drives: 09 5MT
Clutch replacement...now worn wheel bearings???
OK...
Seems as if having my clutch replaced has opened up a can of worms.
After doing the replace (4DSD 5MT, 85K miles), the mechanic said that the wheel bearings are worn and should be replaced. Prior to the change, noticed no looseness in the front end at all. Took it for a test drive just now, and am hearing squeaking noises when starting from a standing stop, and rolling slowly, and it just feels loose.
I did some thread searching, and found a thread that mentions to check the bearings, jack up the car and feel for vibration on the springs while turning the wheel, which I can do this weekend.
My question is more around whether having this sort of work done can cause worn bearings to become more pronounced, since you are really ripping some major axle parts away from their prospective homes, so to speak.
Thanks in advance...Eric
ejaf is offline   Reply With Quote
Old 02-01-2017, 11:15 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
did he tighten the axle nuts? Loose axle nuts will make the car feel weird. Pop you hubcaps off and throw an eye at the axle nut see if anything obvious is going on
I'm at 125k and my wheel bearings are excellent, I did my clutch 3k ago and have not had any issues other then I should of did the transmission to axle seals (which ended up leaking & I replaced today actually) but that happens when you disturb a seal that has not been touched in 7 years
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-02-2017, 09:27 AM   #3
ejaf
Drives: 09 5MT
Will do that this weekend...have to get at the ABS sensor on the right front anyway (another thread).
Thanks.
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Differential bearings worn out - car shaking Unicron DIY / Maintenance / Service 7 06-13-2012 01:07 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
