Old 05-25-2024, 09:48 AM   #1
awill1187
Drives: Totoya Yaris VVTi
Toyota Yaris 08 plate Automatic - Leak
Morning all,
Hoping someone can help with some advice/guidance.
The Mrs has an 08 Toyota Yaris VVti Auto - there is a very slow leak (literally a couple of drops of oil a day) coming from under the car. We returned it to the dealer that it was purchased from and they said they fixed it (which they haven't) - can anyone advise on what the issue is with this/where the leak is coming from - I am thinking it could be the driveshaft seal (might be wrong) - if this is the case, I assume its just a case of removing the drive shaft from the passenger side, remove the old seal and put a new one in?
I cleaned all around the case last week - around the seal area with the drive shaft is wet, and on the second photo you can see a couple of drops forming under the bolts so I am thinking it is the seal where the shaft goes into the case (passenger side)
Any help appreciated
awill1187 is offline   Reply With Quote
Toyota recalling 1.53 million cars globally fnkngrv Off-topic / Other Cars / Everything else Discussions 2 10-21-2010 02:26 PM
