Old 02-26-2009, 12:23 PM   #1
Over40
Over40's Avatar
Drives: SilverYaris
Turbo Charged Normal Engine Temp.
Hi you all,
I feel that turbocharged engines have higher temperature compared to N/A. Is this true?
Mine's felt hotter after installing the turbo. Even on easy daily driving conditions.
Would an effort to lower this heat (i.e. by installing an oil cooler, extra fans) have a benefit in increasing performance?
Appreciate your opinions and pointers.
tks.
Over40 is offline   Reply With Quote
Old 02-26-2009, 12:42 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Increasing performance... NO
Increasing the life of the engine... YES
First you should install some temp gauges (oil , water) to determine how hot are you really running...
An oil cooler would be a nice addition for your turbo set up.
Radiator and stock fan on the Yaris are quite capable... unless you are tracking your car, they should hold up.
Old 02-26-2009, 12:44 PM   #3
Engine temp won't affect power, I think - but the temp of incoming air/fuel will. Might affect longevity though.
Do you have a water temp gauge installed? These little motors run pretty hot anyway. An oil cooler is an excellent mod to add to your car.
Old 02-26-2009, 12:45 PM   #4
^ haha, we were both typing the same stuff at the same time...
Old 02-26-2009, 01:33 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
actually, engine temp does affect power
i've not seen any overly-hot temps in either my oil or water temp gauges.. yes it's warmer but not THAT much warmer
(i have a twin cooled turbo, i actually run the coolant for the turbo THROUGH the heater core so this may be why my car stays cool)
Originally Posted by xnamerxx
you nailed it sir.
Tamago is online now   Reply With Quote
Old 02-26-2009, 02:27 PM   #6
Over40
Over40's Avatar
Drives: SilverYaris
CASTREX & CALI YARIS: OK, I'll install Temp gauges first to determine how hot.
I agree with CASTREX on proper cooling prolongs engine life.
BTW, why do we need both Oil & Water temps ... wouldn't either one represent the condition of the engine itself. I'd hate to clutter my A-pillar with to many meters.
Tamago: twin cooled turbo ... interesting? Do you have the thread showing the application?
O yes guys, oil cooler is already installed.
Thanks guys, very much appreciated ... I'll update after gauges are installed.
Old 02-26-2009, 02:42 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
almost all OE turbo applications are twin (oil and water) cooled
http://www.scionlife.com/forums/view...943&highlight=
you nailed it sir.
Old 02-26-2009, 02:45 PM   #8
Tamago
Tamago's Avatar
Drives: ZZW30
you could get a gauge display like this..
http://www.evasivemotorsports.com/Me...&Store_Code=EM
that would cut down on clutter
oh and i installed my water temp sensor at the radiator outlet, not at the point the water comes out of the block..
my rationalization is, there's already an OE sensor at the outlet, why not keep an eye on how hot the water is going back IN to the engine?
you nailed it sir.
Old 02-27-2009, 07:42 AM   #9
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Hi you all,
tks.
In theory Turbos can really reach high temps. There are many things to consider like the:
- turbo position (if its at the front and moving at 80km/h it will recieve a good amount of airflow, if its at the back, air is mainly restricted by the engine itself)
- if turbo is water cooled
- model & tech of turbo (Consider the smaller the turbo is, the more is activated with lower revs)
- Engine capacity (Consider temp of engine + turbo temp + ambient temp = total temp)
There are things one can do to reduce temps:
- Bigger radiator combined with a well branded water coolant
- Oil cooler with dual circuit to cool the engine and turbo in a separate link
- Consider upgrading hood and front bumper with vents appropriate for your setup
- Upgrade of water and oil pump for better flow
Altough some seems extreme I am quite more relief to have an engine with stable temperature which can cause future problems. Also agree with caliyaris about the gauges, a must to have oil and water temp at least.
Cheers!
Parmas is offline   Reply With Quote
Old 03-01-2009, 02:27 AM   #10
Over40
Over40's Avatar
Drives: SilverYaris
to Parmas: your suggestions are appreciated.
At the moment I am installing an oil temp gauge, and I am constructing an hood air scoop to vent the turbo (the turbo manifold is behind the engine block)
My assumption of getting temp lower comes from my experience, that on hot afternoons, I can only run my car max of 180kph, but on cool nights, I can get it to 200kph (same road...). Aside from other aspects (cooler air) and engine lifetime, I just want to assure that cooler engine provides better power.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
so can you turbo the yaris without check engine lights? letstry1234 Forced Induction Forum 40 01-08-2009 12:48 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Engine Swap / Turbo.... Sabretooth Forced Induction Forum 10 09-13-2007 07:23 PM
