Old 12-29-2008, 09:46 PM   #1
xpeteyjtx
Drives: 07 BB Yaris
motor oil drain plug washer
Has anyone purchased that plastic washer for the drain plug? How much does the dealer want? Does anyone know the size?
I should have taken out the calipers when I was doing my oil change and measured the washer... maybe I could get some replacements from a parts/hardware store for cheap.
xpeteyjtx is offline   Reply With Quote
Old 12-29-2008, 10:21 PM   #2
gid
Drives: '08 Yaris sedan , '08 Liftback
we were given them for free with TOYOTA oil filters we bought . Not sure of the price , maybe the dealer that you purchased the car from would give you 1 or more at no / low cost . Can't hurt to ask . GOOD LUCK
gid is offline   Reply With Quote
Old 12-29-2008, 10:28 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
i paid a $1.50nz for my washer on the last oil change , bought it from Toyota
Old 12-29-2008, 10:30 PM   #4
auxmike
auxmike's Avatar
Those washers are aluminum with a blueish gray paper adhered to both sides.
I got 10 for $10 shipped on Ebay.
I'd only use a dealer part here. Too "mission critical" at part to skimp on....
Old 12-29-2008, 10:29 PM   #5
03Z33
03Z33's Avatar
Drives: TCR10
They're usually less than $0.20 at most autoparts, around $0.50 at my local Toyota dealer.
03Z33 is offline   Reply With Quote
Old 12-29-2008, 10:32 PM   #6
gid
we were given those as well . There's 2 type . The plastic would be longer lasting .
Old 12-29-2008, 10:43 PM   #7
xpeteyjtx
Drives: 07 BB Yaris
I bet I could get some cheap aluminum washers from the hardware store. I guess I will have to measure the diameter of the thread next time.
Old 12-29-2008, 11:04 PM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
To answer your question 12.mm (1/2") replaced my drain plug
with a alloy one with a magnet in it
Old 12-30-2008, 08:44 AM   #9
xpeteyjtx
Drives: 07 BB Yaris
you are the best
now I need to find a 13-14mm (.562") ID aluminum washer
so what exactly is the thread on the drain bolt?
Old 12-30-2008, 01:37 PM   #10
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
you are the best
The TOY washer for the older 2azFE is better being rubberized and good for 4-6 uses if you dont WAIL on it torques wize. - and only a masochist would pay a buck for a 2 cent washer. I would not use Al here though due to possibility it would corrode OFFF the car in the winter, maybe instead a solder tinned Cu washer. That being said I DID spend a buck on this 5c washer at the dealer 'cause I was TOO LAZY to walk into the hardware store and look for copper washers ... So I am Lazy but NOT a masochist
bro for sonja
TheSilkySmooth is offline   Reply With Quote
Old 12-30-2008, 01:41 PM   #11
TheSilkySmooth
you are the best
On a related subject, Though they are good filters DONT use thepurolator filter 'cause the nipple on the filter mount is too short and you will engage less than 2 threads - which is recipe for disaster.
Any one else have short nipple or is it just our car(08 3dr 1.5L 5 spd)
hey xpete, I'm in Wilmington, MA
Old 12-30-2008, 12:10 AM   #12
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
It's Toyota part # 90430-12031. That's 10-pack.
aca72 is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Magnetic Oil Drain Plug PetersRedYaris DIY / Maintenance / Service 13 11-16-2010 07:41 PM
Magnetic drain plug proof ! usmc DIY / Maintenance / Service 26 11-17-2008 07:55 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 02:55 PM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 09:01 AM
