Old 11-22-2008, 12:08 PM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
Tanabe NF Pics
Well after having the NF's on for about a month....i dont like them at all. Now maybe it is because of my tire and offset (215/45/17 +38) but I rub all the time. Right when I put them on automatic rubbing on the front left, even going like 30 on an on ramp, and dont even get me started on dips on the freeway. And last night i finally had some more peeps in my car and i was rubbing like crazy in the back. I can tell that they do handle better and the stance is way nice, but if you got big wheels then these are not for you.
The second to last pic is without the springs =p
So besides the rubbing factor i like them but that is a HUGE FACTOR......i really wish i would have saved and got coilovers
falkor_99 is offline   Reply With Quote
Old 11-22-2008, 12:34 PM   #2
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I'm no tire expert like Kimona, but I think you probably want to go with 205's.
I'm running df210's with 205/50/15 and rarely rub. Only on really big dips.
Old 11-22-2008, 03:45 PM   #3
falkor_99
falkor_99's Avatar
yeah thats probably what i should have went with. But i wanted the 215 just in case of any curbs that would want to attack my wheels =p
Old 11-22-2008, 07:15 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Low offset wheels + tires too tall + tires too wide = rubbing ... A 205/40/17 (1/2 inch short) works well for drop springs. A 205/45/17 is 1/2 inch tall. A 215/40/17 is factory diameter, but a bit wide. Your 215/45/17's are way too tall and too wide.
On a positive note, the drop on your car looks perfect...
PetersRedYaris is offline   Reply With Quote
Old 11-23-2008, 02:34 AM   #5
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Screw the coilovers! You need to get some better shocks, especially with your wheel/tire setup. I was running tein s-techs with stock shocks, and rubbed like a mofo. I then got some tokico hp shocks, and the problem was solved. So if you are on stock shocks, you need to change them out. You can get some good ones for $300, or you can "save" your money to spend on $1000 coilovers.
marlondog is offline   Reply With Quote
Old 11-23-2008, 04:45 AM   #6
falkor_99
falkor_99's Avatar
I was thinking about getting new shocks too.....and now that i know someone else had a problem like me and got new shocks maybe i will consider that route instead of spending the big bucks thanks
Old 11-23-2008, 12:35 PM   #7
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Being on NF's the Tokicos should solve your problems. They did for me but I'm on 15's.
bdc87 is offline   Reply With Quote
Old 11-23-2008, 10:39 PM   #8
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
I've got NF210's with 205/40/17 +40mm offset and I have no rubbing issues unless I'm running down the highway at 80mph and I hit a big bump on the interstate and then I get a slight rub sound on the inside wells against the plastic liners.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 11-24-2008, 06:01 PM   #9
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
NF210s 205/50/15 Dunlop M3 snow tires
CLA 250, 4MATIC
WeSellCarParts.com // Tanabe! WeSellCarParts WeSellCarParts 61 01-17-2009 04:32 PM
Quickie pics of the Tanabe springs install Nimble Photo-Video-Media Gallery 31 07-26-2007 04:55 PM
Pics of Sedan with Tanabe NF210's? SimpleMan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 05-26-2007 03:57 PM
Deals Gap pics HTM Yaris Photo-Video-Media Gallery 3 05-15-2007 07:02 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 08:45 AM
