![]() ![]() Drives: '07 Yaris 3D HB Auto Join Date: Jul 2007
Help Needed: Unlink A/C to Defroster
I don't like the way how the A/C has to be on when I turn on the front defrosters. I think there are two ways to fix this: fake out the detector switch so the car doesn't know you turned on the defroster, or kill the circuitry that automatically turns on the A/C.
In case you don't have the Factory Repair Manual Handy: http://www.etimago.com/yaris/repairmanual/EWD.pdf http://www.etimago.com/yaris/repairm...nditioning.pdf This might get a little technical: Option 1 One guest is that the switch could be inside the control knob itself, and the signal could be turned off by shorting the signal wire or soldering in a resistor. Take a look at page 245 of the Air Conditioning manual for more info about this. Or there could be a switch in the air damper that controls flow to the front defroster. See page 10. Option 2 The Electrical Wiring Diagram Manual (filename: EWD.pdf) on page 239, 240, and 330 mentions "Defroster Mode Detection SW" in the context of air conditioning. SW means switch. The problem is that I don't know where this switch is physically located in the car. The diagram on page 50 and 52 might help answer this question but I can't put the two together. Any help is appreciated, and I know I'm not the only person who wants to get rid of this. |
| Gas mileage and A/C | Chaad32 | General Yaris / Vitz Discussion | 18 | 01-29-2009 05:31 PM |
| Do u guys set to Fresh Air for A/C? | hans_fh | General Yaris / Vitz Discussion | 17 | 06-12-2007 04:24 PM |
| A/C & Aftermarket intake | KSIbucky | DIY / Maintenance / Service | 2 | 03-26-2007 10:08 PM |
| A/C smelling weird? | Yaris_PR | General Yaris / Vitz Discussion | 11 | 08-04-2006 09:26 AM |
