![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Anyone test the turbulence on the back of the car?
I am just about to put some Vortekz generators on the rear of my LB's roofline. I'm going to do a before and after video of the airflow on the rear hatch.
Anyone else do this sort of thing? I'm wondering if the Vortekz can cut some drag. The other choice was to get a spoiler to spoil the airflow but these were a little cheaper and they would be unique. Lastly, I saw a picture somewhere of a YW member that was using Vortekz. I can't find that picture anymore. Any hints?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Kaotic Lazagna has them, check his garage
Thanks, I'm trying to figure out if they should be in a straight line or follow the curve of back of the LB.
I'll go look at his garage now.
some have even angled the right and left half inward as well
Yeah, that's actually part of the instructions. The middle ones angle in the most. Then the angles get less in pairs until the outer ones are parallel.
I can't drive consistently. My right foot wants to activate the S/C. My ScanGauge says "what are you doing to the trip mileage?"
lol, yep, that'll do it
I installed them using the default set up that Vortekz recommends. I saw a very minor (something like .xx, can't remember the exact numbers) increase in mpg. I'm sure if you have access to a wind tunnel or something equivalent, you can angle the VG's better for that straight flow effect.
Also, I know the VG's are working because I can see "triangles" form on my rear window when there is condensation on it. |
Thanks. My problem is that the rear edge of the LB is curved outwards. The rear edge of the sedan is a straight line. I'm going to write the Vortekz people to find out if I should put my generators in a straight line or follow the curve of the hatch.
Parallel Parking Pro
I believe the first common use of the vortex generators was on the Mitsubishi Evo and it was meant to smoothen airflow so that the spoiler/wing on the rear trunk was more effective.
Those followed the curve of the rear windscreen edge, I believe. I don't know how that theory works on a liftback, though, since there is no rear wing to take advantage of the smoothed air. Try it by all means, I think you could probably try both a spoiler or a vortex generator to see which creates less turbulence/drag. Based on the amount of dirt/dust that clings onto my rear windscreen, I think the air moving in this region is relatively slow. I'm thinking of fitting a spoiler to reduce the amount of dust that clings onto the rear hatch.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
We've gotten into the spoiler/dust/mud debate before recently, check it out. Filling in the vacuum behind the hatch is difficult, and is likely to decrease one's fuel mileage. Changing air direction results in drag, simple as that, so I wish you luck.
What I DO know for sure is that the rear window on our sedan remains clean, and the reason is clear when one looks at the profile. My buddy has a hatch, but so far I haven't found the time to do any experimentation... |
| may be emigrating to china, should I sell, or give car back, also running on spare. | waylandchin | General Yaris / Vitz Discussion | 29 | 08-17-2009 07:38 PM |
| Bad Luck, Car Accident | KKevin | Australia | 14 | 12-05-2008 01:43 AM |
| How to Be a Street Racer - General Life Guide | MDF | Off-topic / Other Cars / Everything else Discussions | 7 | 03-19-2007 01:49 PM |
| Test drove 2007 Nissan Versa | Hyde | Off-topic / Other Cars / Everything else Discussions | 33 | 10-20-2006 11:48 PM |
| 07 yaris liftback and 06 xa test drive | extenny | General Yaris / Vitz Discussion | 12 | 05-31-2006 12:56 PM |
