Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Sponsors Classifieds Area > YarisUniverse
Old 11-13-2008, 09:12 PM   #1
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS
Special Introductory Sale, PM for pricing
Drilled/Slotted and Slotted Rotors
Disc Italia is widely recognized as one of the world's highest quality racing brake rotor manufacturers. They are made from unique high carbon steel castings which reduce noise, and vibrations caused by the brake system, and are manufactured to the strictest tolerances. Their drilled and slotted cast rotors provide a bold, aggressive appearance. The bi-chamfered holes help prevent stress cracking which occur in lower quality rotors, and improve air circulation throughout the brake disc; this allows for the disc to operate at cooler temperatures than a traditional brake rotor. The end result is a rotor that outperforms and outlasts the competition while providing smooth, consistent braking throughout the life of the rotor. Disc Italia brake rotors are compatible with stock calipers, and pads, and do not require any special modification to install.
Titanium-Kevlar Pads
The Disc Italia Titanium Kevlar brake pads are designed for today's most demanding drivers. They provide very high friction co-efficient levels & increased braking performance. Disc Italia pads [although not required] are optimized to perform with drilled or slotted rotors. The unique Titanium coated fibers strengthen the pad, giving it increased pad life ensuring you receive a long-lasting smooth operating brake pad, and provide the pad with greater resistance to brake fade. The Titanium Kevlar formulation emits extremely low levels of brake dust ensuring that your brake pads run virtually dust free. All this is achieved without the pad being overly aggressive on your rotors. Each pad sets include integrated constrained layered anti-squeal shims, and the backing plates come with a corrosion-resistant black powder-coated finish. Experience the future of brake friction materials, experience Disc Italia.
kargoboy is offline
Old 11-14-2008, 12:58 AM   #2
*MAD DOG*
*MAD DOG*'s Avatar
What is the difference between the drilled and slotted discs? (apart from drill holes and slots) Do they perform differently?
*MAD DOG* is offline
Old 11-14-2008, 01:06 PM   #3
kargoboy
kargoboy's Avatar
Heat and moisture dissipation under hard braking. If you track your car it's definitely the way to go. If you just like to engage in some spirited driving
the slotted only would be enough, although a lot of people just like the look. The addition of slots and holes will take a toll over time on your pads.
The Titanium/Kevlar pads are designed to work with these rotors and discourage
premature wear.
kargoboy is offline
Old 11-14-2008, 12:08 PM   #4
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
different heat dissapation? aesthetics sometimes if its bad quality rotors like on ebay ones
Nexus1155 is offline
Old 11-14-2008, 02:58 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
sweeet..
marcus is offline
Old 11-14-2008, 03:01 PM   #6
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
if you do decide to get some drilled or drilled and slotted, get good stuff like these, stay away from no name brands or cheapo ones. they will warp and/or crack.
mikenacarato is offline
Old 11-14-2008, 03:55 PM   #7
kargoboy
kargoboy's Avatar
As soon as I get enough money together I'm getting them for my Protege.
My wife doesn't drive the Yaris hard enough, lol.
kargoboy is offline
Old 12-06-2008, 04:35 PM   #8
kargoboy
kargoboy's Avatar
Bump!
kargoboy is offline
Old 12-08-2008, 04:06 PM   #9
MaxT
Drives: 2008 Yaris Hatchback
I purchased a set of the Italia slotted rotors and the pads. Quality is excellent. I do not race so the slotted rotors do not necessarily help but they do look very good through my wheels. The stopping is much better and I attribute that to the new higher quality pads. Well worth the cost.
Installation was easy if you have confidence in replacing brakes. You have to remove two 14MM bolts to get the calipers off to replace the pads. There is a couple other steps in replacing the pads. The original pads have two removable shims on each pad. The new Italia pads have one permanent shim installed on each pad. I took the outside stainless shim off of the original pad and clipped it on the new pads to make the same size pads. You also have to remove a small spring clip from the top of each original pad and attach it to the new pads. Again easy if you are conficent changing brakes, otherwise get help or pay someone.
If you are replacing the rotors you must remove two 19MM bolds holding the caliper cradle on. The rotor should them almost fall off. One side did for me but the other had slightly rusted into the wheel axle but a rubber mallet got it off. Toyota also puts two drilled and tapped holes that you can thread a bolt into to push the rotor loose if needed.
I love the look and feel of the brakes. I'm going to change the lines next because I think that will make the biggest difference due to pressure loss. If you need new pads or rotors, I highly recommend these. If you live in South Georgia or North Florida, I'll gladly help.
Max
MaxT is offline
Old 01-20-2009, 04:43 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Max
nice write up but do you have pictures of finished product????
ROCKLAND TOYOTA is offline
Old 12-08-2008, 09:28 PM   #11
kargoboy
kargoboy's Avatar
Thanks for the nice review!
kargoboy is offline
Old 01-20-2009, 01:42 PM   #12
kargoboy
kargoboy's Avatar
Bump!
kargoboy is offline
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
New Pads and Rotors after 18K Miles??? dadi_oh DIY / Maintenance / Service 19 09-06-2007 08:52 AM
