Old 12-06-2008, 03:01 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
How did you run the wideband A/F cable into the car?
I just got a wideband A/F gauge and the sensor unit needs about a 1 inch hole to feed through. The other end is a rectangular plug and needs a 1 1/4" square hole.
I figured the 1" hole would be easer. I'll be getting a bung welded to my midpipe right after the Megan header. The exterior cable with the two ends mentioned above is only about a foot long.
Is there a large enough feedthrough that exists or did you guys drill new holes into the car?
TIA
Old 12-06-2008, 03:37 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
should move this to the FI section
Old 12-06-2008, 04:50 PM   #3
LtNoogie
LtNoogie's Avatar
It applies to anyone who wants to install gauges but is looking for a DYI on running wiring into the interior.
BTW. I've already used the hole in the firewall that is next to the ECU.
Old 12-06-2008, 05:55 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Is there a rubber floor plug? Sorry, I no longer own my Yaris. Also, You could buy a correctly sized rubber gromet and get a 1inch hole saw drill bit...
PetersRedYaris is offline   Reply With Quote
Old 12-06-2008, 06:03 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
passenger side, where the floorboard meets up with the firewall there is a hole and grommet that you can use.... I seem to remember, but I am not sure, as I no longer have my yaris anymore and the wife will not let me lay a hand on hers
Old 12-07-2008, 01:00 AM   #6
LtNoogie
LtNoogie's Avatar
Thanks, Red and Black Yaris. I'll look under the car.
Old 12-14-2008, 07:04 PM   #7
what did you end up doing for this?
Old 12-14-2008, 07:18 PM   #8
LtNoogie
LtNoogie's Avatar
I haven't. It took me too long to change the plugs and the intake, plus clean up the S/C cable that I did not get a chance to get to it. I can't have anything loose in the car for AutoX and having a gauge laying on the floor won't cut it. I think I'll get a chance next Saturday and will take it to the muffler shop. It should be easier to see my options when the car is up on the lift.
Old 12-14-2008, 07:26 PM   #9
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i cut the stock o2 sensor grommet open (secondary) and slipped the wideband in with stock wiring, then glued it back shut
Tamago is online now   Reply With Quote
big older car vs little newer car xed General Yaris / Vitz Discussion 9 09-16-2007 05:35 AM
New Siphon Mag: Yaris vs. xA vs. Versa vs. Fit @ Streets of Willow Ran Kizama General Yaris / Vitz Discussion 9 06-18-2007 01:42 AM
where to run amp positive cable??? punch In Car Entertainment + Electronics (audio / video / alarm) 8 12-21-2006 08:50 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 02:05 PM
Buying a first car..lol Blenjar Off-topic / Other Cars / Everything else Discussions 11 06-14-2006 12:58 AM
