Old 12-08-2008, 11:31 AM   #1
iwantayarisnyc
Drives: 08 sedan auto
does anyone get synthethic at toyota dealer?
just curious if you watch the mechanic pour synthethic oil from containers
and how much the oil change costs with synthethic....
iwantayarisnyc is offline   Reply With Quote
Old 12-08-2008, 01:20 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Dont do it! Buy some Motul 8100 E-tech or Elf Excelluim renault/peugeot spec and DIY. Check LTB motorsports
- the bro
Old 12-08-2008, 03:52 PM   #3
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
My dealership wanted to charge $75 for a synthetic Mobil 1 oil change. So ya I just bought some Royal Purple and a Wix filter and changed it myself.
Old 12-08-2008, 04:42 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Our dealer has a 360 degree glass waiting room above the service area so every one who's waiting can watch the mechanic work on their car.
They charged me $60 for a Mobil1 plus filter change.
Old 12-08-2008, 04:48 PM   #5
gid
way to expensive . Go to ADVANCE AUTO PARTS , BJs WHOLESALE ( Shell synthetic , $4.19 a qt. ) , WALLY WORLD , PEBOYS , AUTOZONE , or others for better price . Get oil yourself and have them do the oil change by substituting the regular oil with the synthetic you bought and still using their oil filter , a TOYO ( Denso ) I assume . I would think the total cost would be $40 or a bit more . If you do so , bring 4 quarts of the synthetic and tell them to pour 3 and a 1/2 quarts in for the fill . This will bring it to or a tad below/above the FULL line on the dipstick . Read dipstick before leaving the business to make sure oil was installed , we've had them not fill ( possibly 1/2 qt. oil ) or overfill ( 1 qt. or > ) the engine in past . Then , recheck oil when car has been sitting for 1 hour or more on a level surface . Last , look under the car for leaks on occasion ( loose oil filter ) . My better halfs ' brother had a well known oil change chain not tighten the filter on his TACOMA . Luckily we were around to notice the oil spewing from under the truck and had him come to house so I could tighten the filter and pour in 4 quarts of oil I had in garage . Quite messy as well . These are the reasons why I now do oil changes myself . Plus it's cheaper .
Old 12-08-2008, 05:03 PM   #6
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Originally Posted by gid View Post
way to expensive . Go to ADVANCE AUTO PARTS , BJs WHOLESALE ( Shell synthetic , $4.19 a qt. ) , WALLY WORLD , PEBOYS , AUTOZONE , or others for better price . Get oil yourself and have them do the change .
Actually found Walmart to be the cheapest in our area, beating Costco. I pick up an OEM filter and have it changed for $10 labor/disposal. Total cost is about $35 this way.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 12-08-2008, 05:05 PM   #7
iwantayarisnyc
that's the thing, i could definitely change the oil myself, but i want to leave a record. i don't think a receipt of the syn oil + filter would do. i want a receipt from a mechanic place, etc
however, dealers get their oil change marked up in carfax....which is even better.....when people carfax your car(when you plan to sell) they will see a service history.....
Old 12-08-2008, 05:23 PM   #8
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I do my own Mobil-1 oil changes with a Puralator filter for about $35.
Old 12-08-2008, 07:53 PM   #9
ddongbap
Syn oil is kinda over rated.
Old 12-08-2008, 08:22 PM   #10
Thirty-Nine
Why?
Old 12-08-2008, 08:23 PM   #11
ddongbap
Why?
Why would you spend more on oil? Esp on a teeny weeny engine like our 1NZ?
Old 12-08-2008, 08:50 PM   #12
Thirty-Nine
Because it's better for the engine? I don't care how small the engine is; I want my engine to perform at its peak and last as long as possible, since I do not plan on getting rid of the Yaris until it dies. I guess it depends on how you look at it. Why run synthetic in any engine?
Old 12-09-2008, 12:41 AM   #13
ddongbap
Can you prove that syn oil, changed at regular intervals is any better than conventional, changed at regular intervals?
Old 12-09-2008, 01:43 AM   #14
gid
1 reason ...
it works harder . Especially on interstate , steep hills , etc..
Old 12-08-2008, 08:28 PM   #15
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Well you could ask to watch............
As far as cost since Toyota dealers are independantly owned they are permitted to chage whatever they want........ so the best advice is to ASK THEM.
Old 12-08-2008, 08:54 PM   #16
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
+1 :) royal purple ftw!
Old 12-09-2008, 01:51 AM   #17
gid
plus the comfort of knowing it's synthetic . SECURITY BLANKET for you and your YARIS (es) . Sleep well baby YARIS .
Old 12-10-2008, 01:49 PM   #18
TheSilkySmooth
I just made the switch on Sis car to MOTUL 8100 SYN ACEA A5/B5 (their cheapest stuff) and the car runs noticably better than the M5000 I was breaking it in on. Smoother more stable idle and no noticable performance loss during warmup of the oil ( 15deg F to 195+). Car is less buzzy on the interstate at 60-70mph and the apparent midrange torque is improved (you call "butt dyno"). Cant prove it but like it. This is PAO base so not as good as MOTUL 8100 E-Tech or 300V. PAO syn is Good for winter, polyol esters for (or DI-A ester) for race or hard summer use..
_
_
#1 benefit - of REAL syn? Near zero (-0-) varnish behind piston and in chain tensioner area
Biggest zone for performance issues on modern tight tolerance engines.
Second benefit is more shear stability around the piston - so less gum higher balanced compression, less chance of stuck ring and consistent piston-will lubrication day in and out. Tear a few hundred motors down in your carreer and you will see what I mean ....
Little means HARD WORKING: Any high-specific output engine needs TLC ( yaris makes over 1-HP per Cu/In so it is POWERFUL for a1-Atmospheric engine If it was sized up to a 6.2L Chevy V8 it would be like 450HP!!
- Sonjas Bro
MOTUL is famous for their Lemans 20 -60 Race oil ( and NO dont put it in your yaris) I don not work for them
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 09:59 PM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 12:32 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 04:16 AM
Detailed dealer pricing on the new, 2007 Toyota Yaris. tomjasz New YARIS Purchase Forum 3 08-11-2006 11:46 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
