Party like a Barack star
Drives: '08 LB MT Join Date: Oct 2008
After the first oil change...
I still don't have enough miles on my car to have had the first oil change yet, but I heard that your mpg/ FE will improve slightly/dramatically once I get it changed for the first time...
Can you please share your experience?? Can you confirm/deny this??
i don't feel like creating another signature, yet. Give it another week... |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
I have 2 Yaris's and neither one of them got an increase after the 1st oil change. Of course I have never got less than 36 mpg in either one of them.
Switch to synthetic and you'll see a little extra bump.
how much "little extra" ?? Does it justify the cost of the oil??
I saw 1-2 MPG. That isn't why you should be using synthetic, though. You should use synthetic because it is better for your engine and gives it a chance to last longer.
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I noticed a 1.5 Mpg increase, after the first change and putting in Mobil 0W syn. But I also got a similar increase from a K&N filter, and from adjusting the tires from 28 to 42psi.
I can't prove if it was the oil, engine break-in, or just my habits adjusting to the new ride. Good news is that for a number of reasons, your MPG should increase by some measurable amount in the first year. I did see a short lived increase after the second change (120+ mi/day adds up) but my situation changed and I added a carpool mate 2 days week which lowered my average a similar amount. With the same car but at the opposite end of the country I am getting 40 - 42, with a high of 44. Weekend driving and other things slightly change my results from tank to tank, and "your results may vary..." |
you should always change your oil the first time before 3000 miles.. that's break-in oil inside your engine and it needs to come out after 1000miles..
Wouldn't Toyota recommend that I have the oil changed before 3k miles then? If it will prolong the life of their produce, you'd think that they would mention this...
#9 | |
dealers make more money fixing cars then selling cars ;) |
True that Toyota doesn't want their engines to last forever, but common sense also tells you that they don't want sludge (or break-in oil) in their engines either. They didn't build a reputation of being dependable by fixing cars, they built their reputation by manufacturing cars that required little service. ;)
#11 | |
i'm not knocking toyota, but why wait to take out that break-in oil? just because toyota doesn't tell you to do it does not mean you shouldn't... if i followed toyotas recommended 5000mile oil change on my car i'd likely destroy my engine.. |
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Oct 2008
I always go every 3k, I don't care what the dealers say about every 5k, I've had my LB for almost 2yrs now and love it, I never go beyond every 3k (sometimes every 3200) lol
I frackin' love my yota!!!
Visualize whirled peas. Peace, Love and Good Smoke! --Tommy Chong
I'm running Motul 300V 5W-30, changing every 3-4K miles, and I'm getting 39-41 mpg (even with the new tires). In my experiance the 1NZ seems to respond to high quality synthetic motor oil quite well. The C60 trans also responds to Redline MT-90 trans fluid. I have a feeling both of these fluid swaps are a big reason why I'm getting such good mileage, seeing as how I don't drive for fuel economy in the least.
#14 | |
Thanks anyway.
#15 | |
![]() Drives: 2008 Toyota Yaris, automatic Join Date: Oct 2008
![]() I'm convinced no one can say with any certainty either way. So I'm going 5000 mile changes and staying with dino oil. I've done this before and the engine looks like new. I still plan to get 200,000 miles out of it. Then everything else is falling apart by that point. |
#16 |
^^^ true... It just seems that if it were best for the engine, Toyota would recommend in the Scheduled Maintenance Guide to change at first 3k miles, then every 5k after that. I am with you briman. I am doing 5k and expect this car to last forever :)
#17 |
I just changed the oil in my 08 this past weekend after putting 5000 miles on. The oil that came out looked brand new. I have also talked to several Toyota mechanics and they told me that the each engine is tested for 500 miles(calcualted by a computer) before they are dropped into the car, then they drain the oil and put new oil in.
#18 |
![]() Drives: 08 lb Join Date: Oct 2008
had first change today @ 2000 miles, dont see how it can hurt anything to change it but can think of many ways it can by not.... but i will continue at 5k ish from here on w/dino
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
