![]() ![]() ![]() Drives: yaris Join Date: Oct 2008
urGENT. need halp!!!!PLX
So im hooking up my system and ive had the same prob wih 2 amps. I turn the car on, and the light on the amp flashes for a slplit second and then goes off. Then when i trun the key off, it flashes again for a split second. Ive tried everything, i think maybe its a ground ima try to sand down the ground area and then retry it....can anyone else help. Its a pioneer760 peak watt amp and 800w peak sub. THANKS
btw ive been at this project for 6 hours now and its almost 2 am im runnning on Monster and Marlboro excuse the typos
ballin on a budget. |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
It might be your "remote" power, the one you wire to the ignition. Could be the ignition being in a certian position it sparks. Could be worth a check.
got a better ground now and we be hittin up in this beotch (that means the sub is workin)
woot 3 more hours and ill be done, 3 hours before i have to be at work i miss my accord where everythng was held in by one or two bolts instrad of 50,000mini plastic clips
| URGENT help needed :( -DIY springs | Masteraal | DIY / Maintenance / Service | 19 | 12-23-2008 03:23 AM |
| how can u test a sub? URGENT | Sway84 | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-09-2007 02:16 PM |
| urgent info needed..(before going shopping) | seanele | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 07-02-2007 10:07 PM |
| URGENT - CAPACITOR QUESTION | SeriousBlack | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 06-25-2007 09:27 PM |
| Urgent! Driving to Yellowstone from Northern Utah | hans_fh | General Yaris / Vitz Discussion | 1 | 05-16-2007 03:06 AM |
