![]() ![]() Drives: magntic grey Join Date: Dec 2008
steering wheel outta control when im coming to a stop
i just switched over to 205/15/50 from stock
everytime i slowly come to a stop at a crowned intersection its seems like my steering wheel has a mind of its own. the stock wheels felt alot softer and more on control. will the wider tider affect my suspension in the long run? should i switch to 195 or will 205's be ok.>? i wanna keep my rims what can do fix this? btw im planning to lower around 1.5 inches later on. i suspect its gonna get worse. |
What tire did you go with?
205/50/15 on 15x7 alloys
I think he also means, what brand and model?
Also, I noticed the power steering can do some weird antics if the pavement is not so smooth, is that the case?
i found similar things on my XRS when i had 235 tires on it....it would track the grooves in the road a bit more....
youll be ok w/ 205's you just need to compensate more because of it when the road isnt so smooth
205mm tyres are a great fitment for our cars. No worries there. But, occasionally it's just the tyre's tread design that makes the car do squirrelly things. What tyres are you running?
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
When the tyres are wider and the profile is lower you will get a more direct feeling. Especially if it´s a very hard tire you are using. Did you try to squeez the tyres before they were mounted on the rims? Regards Steven. |
| Mesh Steering Wheel Cover... Toxic? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 20 | 07-03-2010 05:53 AM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| audio volume control on steering wheel | hans_fh | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 01-04-2009 09:07 PM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
