Old 03-17-2009, 09:08 PM   #1
CB900F2
Drives: 08 Sedan
WIX Filter - Quality?
Hey guys.. Anyone here purchased a WIX engine and cabin air filter for their Yaris?.. How did you find the quality and fit?
thanks
CB900F2 is offline   Reply With Quote
Old 03-18-2009, 02:46 AM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
My current cabin filter is WIX. I use to have Bosch. WIX fits better than the Bosch. As for the oil filter, I haven't used them yet but you can read many positive response in BITOG.
aca72 is offline   Reply With Quote
Old 03-18-2009, 03:37 AM   #3
mimelio
Drives: NONE
Anything made by Wix is very high quality... NAPA Filters are made by Wix also.
mimelio is offline   Reply With Quote
Old 03-18-2009, 09:15 AM   #4
1stToyota
1stToyota's Avatar
thanks
I like their oil filters better than their air filters. Their cabin air filters seem a little bit restrictive.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 03-21-2009, 09:36 PM   #5
360cubes
Drives: 2000
Send a message via MSN to 360cubes
WIX makes good products and are a base for several other well known brands. I've used their oil filters and for the price offer long life when used with synthetic oils.
360cubes is offline   Reply With Quote
Old 03-21-2009, 09:48 PM   #6
06vitzRS
Drives: 06 Yaris HB
I use wix on my cars. Quality products.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 03-22-2009, 02:50 PM   #7
jay
Drives: 2006 Yaris LE 5dr AT
I'm currently running the NAPA Gold (which are apparently reboxed Wix, I don't know enough about these things to be sure) cabin and engine air filters.
The samples I have are made in South Korea. Price wise, the NAPA Golds were a tad higher than OE (not sure if this is true across Canada).
I can't do a scientific filtering quality test, but both filters are more heavily built vs. the OE Densos. Fit is perfect. At this pt, I don't have reason to doubt their quality.
jay is offline   Reply With Quote
Old 03-22-2009, 08:10 PM   #8
TheSilkySmooth
TheSilkySmooth's Avatar
Check out Federated made by hastings/baldwin (clarecor), Under 3 bucks and top construction. More filter media space in the fed/hastings due to the bypass welded onto the bottom of the core tube. Wix is great, but there aint much room for the filter after the giant wix bypass is located under the base plate.
Old 03-23-2009, 12:17 AM   #9
texkid
The one with cheese on it
Drives: '10 Corolla S
Use both the oil and air filter from Wix. Love them. I might be as bold to say that the "new car" smell is still lingering.....mmmmmmhhhh.......
texkid is offline   Reply With Quote
Old 03-23-2009, 12:53 AM   #10
YarisSedan
Drives: 08 Yaris Sedan
Thier cabin air filters have that special technology that prevents any type of bacterial growth. So no more funky smell in the winter times when you turn on the blower motor.
Old 03-23-2009, 08:08 AM   #11
CB900F2
Drives: 08 Sedan
Thanks everyone for your feedback....
Old 03-31-2009, 07:09 PM   #12
toad
toad's Avatar
Drives: street-legal go-kart
.....so wix is pretty good? how about purolator? my local advance auto parts has them(along with fram-which i hear aren't that good, mobil 1-pricey, and k&n-very pricey). i plan on buying some pennzoil platinum this week for an oil change and wonder if it's ok to buy a cheaper oil filter like purolator(sp?) instead of the pricey ones?
toad is offline   Reply With Quote
Old 03-31-2009, 11:04 PM   #13
OK Yaris
Drives: 2007 Liftback
Originally Posted by toad View Post
.....so wix is pretty good? how about purolator? ?
Purolator is a good filter, as well as many others including WIX/NAPA.
I have been buying Toyota filters in a 10-pack for the Yaris(change oil every 5,000 miles with non-synthetic). I would have no issue buying Purolator or Wix, and many others, but definitely not Fram.
Mike
OK Yaris is offline   Reply With Quote
Old 04-06-2009, 11:22 AM   #14
TheSilkySmooth
I want to know why Honda, Acura and Subaru are using Fram (Honeywell) to make their Service part replacement filters? I just got a filter from subaru and its made by fram! maybe the custom ones made for them are better?
Old 04-06-2009, 11:40 AM   #15
1stToyota
1stToyota's Avatar
You could try Nippon or Beck/Arnley. I was on a Honda forum not long ago and Nippon tested best, so I'd imagine that they're pretty good across their entire P/N line.
2008 Scion xD
Old 04-11-2009, 07:52 PM   #16
TheSilkySmooth
Subaru has this crazy 23psi bypass valve rating that wix doesnt meet, I was gonna use the 51356 instead of the -65 since its much longer than the tiny lawn tractor filters they usually use. I have a rod knock on the subaru (bad luck!) so I'm sticking with OEM service replacement parts until I get this resolved. Right now they dont "hear' anything unusuall. I may have rod knock confirmed by an independant shop to push them into fixing it. Thanks 1st, I'll check into the Nippon
Old 04-12-2009, 12:34 AM   #17
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I haven't had to put any filters on my new Yaris, but I've used both Wix and Purolator filters for many years with complete satisfaction. I'd put a new Wix air filter in my daughter's Echo not long before trading it, in fact. It fitted perfectly.
Old 04-12-2009, 10:14 AM   #18
TheSilkySmooth
Unless they fixed it in the past couple months, the purolator didnt fit correctly on my 08 yaris 3 dr. It only engaged 2 threads fully tightened and thats not enough. IMO the base plate is too far below the gasket surface. Youll see on the oem the baseplate is bumped UP towards the gasket surface instead of concave. I like purolator but this just didnt fit.
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 01:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 07:36 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
2 maintenance issues SilverBack DIY / Maintenance / Service 14 01-03-2009 03:37 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 03:00 AM
