![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Stone chips & rust spots
Hey guys - I was just cleaning my wind shield and noticed there are a couple of small stone chips right where the top of the window meets the roof of the car. Both are pretty small, but they are chipped right to the metal and I can see small dots of rust forming.
Guess they must have happened this winter sometime ... question however. How would you go about getting rid of the rust, and sealing them back up so the rust doesn't spread? I was thinking of bringing it to the body shop but since the chips are so small I thought maybe there was a way I can do it myself ... Thanks!! |
I love momentum.
You could use one of those tiny cone shaped dremel sanding bits to manually (as in use your hand to turn it, not the dremel) sand the rust out of the dot. Prime/paint over it with touch up paint.
You might try Naval Jelley. Dab a small amount with a q-tip on the spot and then with an artist brush touch it with your choice of color. Be sure to follow the instructions with the jelley. If I remember right it is water dilluted so wipe off with damp rag, dry with hair dryer and go from there. Naval Jelley should be found at Lowes or the Depot.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I had a few chips on an 88 Toyota Truck in the same spot left unfixed. The result was that the paint eventually bubbled and rust occured.
Making a decision without following it with an action is still a fantasy. |
I went to the auto body repair section in CTC and picked up a fibreglass pen. Gently rub the chipped area, and the rust comes right out. Works great, and you don't risk damaging the paint around the chip or over-grinding the exposed metal.
So I'm at the dealership and the body shop guy told me to seal the spots with nail polish and when it gets warmer, use the paint pen. He said avoid sanding because it would just make the spots bigger - he also said somethin that makes sense, which is the fact that rust cannot happen overnight, and that the spots are most likely the first stage of oxidization, so if you seal them it will prevent full on rust.
| Rust Protection | casterqc | General Yaris / Vitz Discussion | 12 | 09-20-2010 11:09 PM |
| Stone Chips | Ryu | General Yaris / Vitz Discussion | 3 | 03-12-2010 12:31 PM |
| Rust spots on trunk | minicorolla | Wash, Wax, Detailing, Exterior Repairs | 21 | 04-08-2009 01:02 AM |
| Stone Chips | RandomPilar | Wash, Wax, Detailing, Exterior Repairs | 9 | 08-15-2007 03:52 PM |
| Rust concern due to damage? | Jem_hadar | Wash, Wax, Detailing, Exterior Repairs | 6 | 03-03-2007 08:17 PM |
