Old 02-05-2009, 09:10 AM   #1
otterhere
Drives: 2008 Yaris 3-door Meteorite
Magic Gas
Well, THIS is a new thing (along with the disappearing change)...
After defrosting/warming my car this morning, I got in to see the last bar blinking; yes, I'd been on the second to the last, but defrosting always seems to put me over the top... Or the bottom, as the case may be...
So I'm driving to work thinking I need to fill up later (by now the "cool" light had gone off), when suddenly the bar STOPS blinking, and the second-to-the-last bar reappears... Suddenly I have *more* gas??? Where did it come from???
Always the suprise, with the Yaris!!!
BTW, still getting 32 mpg, despite having inflated my tires to 38 psi (sigh).
otterhere is offline   Reply With Quote
Old 02-05-2009, 10:44 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
it could happen. The way your car is angled.
Old 02-05-2009, 11:04 AM   #3
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
what is your usual tire pressure?
Old 02-05-2009, 11:50 AM   #4
otterhere
When I got the car, all tires were inflated at 26 psi... It took me a while to notice and correct that... But that hasn't helped my mpg, obviously...
Old 02-05-2009, 12:12 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
id go with angled car during parking.. final answer...
Old 02-05-2009, 12:24 PM   #6
otterhere
id go with angled car suring parking.. final answer...
Except that both when parked (defrosting) and driving (noticing the extra bar), I was on a flat surface; no "angles"... And the extra bar wasn't just momentary, but stayed, even when (later) I DID change angles, going up an incline... Try again...
Old 02-05-2009, 12:46 PM   #7
33OH
Drives: '08 Yaris
Well, we all know the gas gauge isn't too accurate. Could have been splashing around when you drove and hit an the higher sensor mark.
No idea why you're only getting 32 MPG's though, that's just beyond me. I don't even get close to that driving in the cold, through the Appalachian mountains every day, doing between 70-80mph.
Unless you're talking a high percentage of city driving..?
Old 02-05-2009, 01:12 PM   #8
otterhere
It's about half and half city/hwy, but even my ALL highway tank was only 36 mpg... I don't get it, either, and I am not happy about it...
My Swift got 40 mpg, as old, cheap, and decrepit as it was... maybe things will improve after the first oil change... Is that covered under warranty at the dealership, BTW (haven't read booklet yet), or should I just bring it to my old change place???
Old 02-05-2009, 01:15 PM   #9
33OH
Drives: '08 Yaris
They don't usually cover your oil changes, unless you got some kind of dealer incentive. I used to go to the dealer, but it's like $45 for just an oil change, so I take it to my old shop now and get charged $25 for full service.
A lot of people are claiming MPG boosts with synthetic, but personally I wouldn't spend that much per oil change. But then again I drive ALOT, would just get too expensive for me.
I'm getting around 35-38 MPG in the winter right now (I'm on snow tires with 32 PSI inflation, as well). In the summer I run 42 PSI on my lighter weight rims and I get mid 40's and have hit 50 once, but I was REALLY trying to hit 50. And this is all highway, my drive to work is about .5 miles in the city and 90 miles on the highway.
Old 02-05-2009, 03:35 PM   #10
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
I drive 50% city and 50% highway.
I was getting 35-37 mpg when the car was brand new.
After a few thousand miles on it, it consistently gets 37 mpg.
I used to get 32 mpg with Corolla, driving 1/2 city and 1/2 highway.
How fast do you accelerate and how much idling do you do?
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 02-05-2009, 03:47 PM   #11
otterhere
I'm very careful not to idle (turn it off if I'll be sitting) and always creep up to stoplights and ease into resuming speed; also never exceed limit now... All my efforts aren't helping, and I did NONE of this with my former car (40 mpg).
Bad fuel filter? What else can I try???
Old 02-05-2009, 06:50 PM   #12
tetzyamis
'09 5dr
tetzyamis's Avatar
I don't know...
To me, you should be getting around 37 mpg.
More so, if you used to get 40 mpg from Swift, it makes sense you get around 37 mpg from Yaris.
Old 02-06-2009, 11:31 AM   #13
otterhere
I don't know...
Okay; although my gas gauge never DID go back to blinking (even after ten more miles???), I went ahead and filled, calculating EXACTLY this time...
35.6 mpg... That's some highway, but mostly city... So it's getting better...
Probably thanks to inflating the tires from 26 to 38; thanks!
Old 02-05-2009, 03:37 PM   #14
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
your exhaust routes past your gas tank..
warming the gas will cause it to expand
Originally Posted by xnamerxx
you nailed it sir.
Old 02-05-2009, 03:45 PM   #15
otterhere
Huh???
Old 02-05-2009, 03:46 PM   #16
33OH
Drives: '08 Yaris
Huh???
He's saying it's possible that since the gas got a little warm (since the car got warm) it heated and expanded a little, making your gas gauge go up one notch.
Old 02-05-2009, 03:50 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
THERE is your answer ;)
you nailed it sir.
Old 02-06-2009, 12:14 PM   #18
otterhere
Except that the engine was cold again THIS morning when I started it, and still I was back at two bars with no blinking, so it wasn't the "cold" engine.
'Tis a mystery!!!
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 09:24 AM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 05:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 09:59 PM
