Old 02-16-2009, 01:21 AM   #1
parce1992
Drives: yaris S hatchback 09
manual transmision problem
hi I have 4 door yaris. manual.
cool little thing
however, sometimes when i put it into reverse it makes a sound as if i did not have my clutch engaged but i do....
I really do not want to ruin my transmission and i have that warranty that covers it all.
So what do you guys think i should do? take it to the dealer?
parce1992 is offline   Reply With Quote
Old 02-16-2009, 01:35 AM   #2
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I think I might know what you're talking about here since I drive the manual as well. It usually takes a moment of clutch engagement before you shift into reverse to make it seem smooth, though it is still a little notchy. Make sure the car is not moving at all when engaging reverse or you will get grinding-which is very hard on the gears. If you're getting grinding and the car is dead stopped and you engaged the clutch a moment before trying to shift into reverse, I'd have the dealer check it before too long to prevent damage.
UTVitz is offline   Reply With Quote
Old 02-16-2009, 03:34 AM   #3
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
Every Honda and Toyota I have never driven from my '86 pickup to my girlfriend's 07 Yaris has done this. Put the stick in a different gear before reverse (without letting go of the clutch). I usually use 4th or 5th since they don't see the abuse that 2nd and 3rd do.
I could've sworn I posted about this not too long ago.
GuySmily is offline   Reply With Quote
Old 02-16-2009, 03:50 AM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I used to have this problem too. I had the bad habit of throwing it in reverse while it was still rolling forward at about 1/2 MPH. It used to make a loud grunt during the shift. What works now is making sure the car is completely stopped first, like UT suggests. Also putting in neutral for a second followed by pinning the clutch all the way down before hitting reverse makes for a flawless shift everytime
Old 02-16-2009, 09:12 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
the square reverse gears don't help either.
i guess most of the tips are already suggested by others... Wait until complete stop, put it in gear before going into reverse.
Old 02-16-2009, 10:42 AM   #6
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
As I have done a lot of driving with my Yaris, I have noticed the same thing. I usually engage the clutch and put it in 4th gear then reverse and it goes in smoothly. And also, make sure the car is not rolling.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 02-16-2009, 12:19 PM   #7
jkuchta
Drives: 2007 Yaris hatch (red)
Change your trans fluid to Redline MT-90.....everything will be much smoother, and the grinding will be pretty much gone.
jkuchta is offline   Reply With Quote
Old 02-16-2009, 01:26 PM   #8
IllusionX
^ jkuchta, you are complete lost in what we are talking about.
Old 02-16-2009, 01:51 PM   #9
1stToyota
1stToyota's Avatar
Mine was that way. Got a little worse when I went LubroMoly synthetic GL-5. Switched to GL-4 Amsoil and problem is about 99% gone.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-16-2009, 01:56 PM   #10
jkuchta
Illusion...I think I'm with you.
The reverse gear is non-synchro'd and straight cut, which makes it a little difficult to engage. I had the same problem myself, especially when the trans was cool in the morning. That grinding sound is what happens when reverse is only partially engaged. Switching to the MT-90 pretty much made the problem go away.
You'd be amazed at what a switch to a good fluid will do for this transmission.
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 10:27 AM
READ YOUR OWNERS MANUAL!! MadMax General Yaris / Vitz Discussion 29 12-14-2008 11:38 PM
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 08:24 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 01:20 AM
