Old 02-24-2009, 04:09 PM   #1
Brian
Brian's Avatar
Center Cap help
I got my wheels installed today but the center caps won't go on the
front wheels. My wheels are SSR Type C 16x7 +42. Anyone else have
this problem with the inside of the center cap hitting the threads? Here's
some pics so you can see what I'm talking about.
Old 02-24-2009, 04:31 PM   #2
I'm checking with Tanabe -- maybe the design of the center caps has changed or something. I know I have pics of my car with the center caps on, and they fit on PeterPoop's car too.
I don't think the front axles are different for the sedan -- anyone know?
Old 02-24-2009, 11:54 PM   #3
Same part numbers for axles and hubs on LB and Sedan.
Old 02-24-2009, 11:56 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
very common toyota issue, the axle stubs stick out too far... grind them off and you should be ok.
Originally Posted by xnamerxx
you nailed it sir.
Old 02-25-2009, 12:07 AM   #5
kou
Drives: 08 lb
ghetto style,paint can lids.
Old 02-25-2009, 12:26 AM   #6
Brian
Brian's Avatar
Thanks. I wasn't sure if I should do it or not. It's not sticking out by too much. Probably about 3/16".
Old 02-25-2009, 08:12 AM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
yeah you should be able to use a 4" grinder on them, no problem. just use light pressure on the edges to avoid "mushrooming" the thread area. if and when you have to remove the axle, spinning the nut backwards off the stub will straighten out any minor thread imperfections.
make sure and shoot the stub with a lil paint after grinding. rust sucks :(
you nailed it sir.
Old 02-25-2009, 08:18 AM   #8
Klink10
Klink10's Avatar
Very nice solution....cheap and easy to replace. I like
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
center caps for enkei rpf1s??? andruboz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-05-2010 11:37 PM
Gas Cap not tight enough? polar_white General Yaris / Vitz Discussion 6 08-14-2007 11:46 AM
center cap removal djfuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-23-2007 01:38 AM
Power outlet cap broke rnd243 DIY / Maintenance / Service 11 01-16-2007 10:26 PM
