![]() Drives: vitz rs 1500 2001 Join Date: Dec 2008
Temperature Guage install
HI Guys,
I Own a Vitz RS 1.5 2001, There is no temperature gauge installed, just an "idiot light", so I want to install a aftermarket gauge,a triple mini gauge set (SUNPRO). Can I use the original temperature sender and connect it to the new gauge? Because I still want the option of the "idiot light". |
You'd probably get better results by putting in your own sensor in the coolant line
![]() Drives: 03 Echo, 04 Scion xA, 02 Range Join Date: Dec 2008
depending on what the other two gauges are that come with the triple mini gauge set, you might be better off with a scangauge.
I'm assuming you mean water temp and not oil temp? Your oil "idiot" light is for pressure, not temperature.
Either way, a decent gauge will come with a new sensor calibrated correctly for that gauge.
| Tags |
| gauge, idiot light, sender, temperature, vitz rs 1.5 |
| Pictures from Sundays 2-member meetup & vinyl install in Portland | Astroman | Photo-Video-Media Gallery | 20 | 02-08-2010 01:55 AM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| where can i install these power locks? | songa | New England | 1 | 12-04-2008 12:41 PM |
| Water temperature | Bob_VT | General Yaris / Vitz Discussion | 11 | 11-03-2008 03:17 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
