Old 02-27-2009, 08:32 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Changing LED's In Projector Head Lights
a year ago i picked up the projector head lights from depo auto. then a few months after i had them i hit a deer and the body shop replaced ONLY the passenger side head light. and they replaced it with a head light from depo that had white/halogen leds int the halos, and my driver side still had blue leds in the halos.
this has bothered the shit out of me. and i emailed depo several times to see if i could order just the passenger side head light with blue leds, andfor whatever reason, i dont know if it was me not following up on the issue or if it was depos fault, this didnt get sorted out the way it should have.
so i just emailed them again about it trying to get another blue one.
but if it doesnt work out i'm considering changing the leds myself but instead of blue i want to change them to red.
never done this before i'm sure it will involve soldering where the leds are inside the halos. not sure about the rest of the work or how to open the head lights but i'm sure it wouldnt be too difficult.
any insight please?
Old 02-27-2009, 08:40 PM   #2
GreenSpeed
Drives: '08 Yaris LB
Been there. Baking the headlights is easy (250 degrees in the oven for about 10 minutes). They actually come apart easier than the stock ones. As for the LED's, if you are referring to the halo ones, you don't need to bake the headlights to get those out. Just take the outer wiring apart from the housing and you will see that the halo LED's are easy to pull out. Once you have them out, go to Radio Shack and pick up a set of replacement LED's. They have them in all colors. Match the size as best you can and solder the new LED's in place of the old ones. It's a bit tricky at first, but with some patience it's not hard at all. I jerry-rigged a flashlight to test the new LED's to make sure I knew + and -. As for the 3 upper LED's in each light, those are a different story since they are a completely different LED set-up. I checked everywhere on eBay to get replacements and they are damn near impossible to locate.
GreenSpeed is offline   Reply With Quote
Old 02-27-2009, 08:45 PM   #3
whooppee777
damn near impossible, does that mean you did not find them or u found them but it took a lot of searching?
Old 02-28-2009, 01:19 AM   #4
GreenSpeed
as in, they have similar replacements, but they aren't quite the same and all of them come from Hong Kong, so it's a crapshoot until you actually receive them. They have a wedge type housing design and none of the eBay ones look the same as the stockers.
Old 02-28-2009, 05:05 AM   #5
Jerkratt
Jerkratt's Avatar
the 3 LED's are 194 wedge's... u can order them from autolumination or superbrightleds if u really want u can go to pep boys or other type store and buy them... carful tho red will get u pulled over
"It hurts more when its wet"
Old 02-28-2009, 11:30 AM   #6
Darb
Bear Traffic Controller
Darb's Avatar
Just a note, Whooppee. Don't drive in VA with the blue LEDs on, the cops will pull you for that. Not sure about Maryland.
Old 02-28-2009, 06:10 PM   #7
whooppee777
i just printed out MD laws regarding colored lights and they prohibit blue and or red lights.
so technically i should have been pulled over for the blue ones.
BUT
what about the new mercedes and audis that have the exact same blue colored leds built in from the factory?
another member said as long as the red or blue lights r low powered and not the actual headlights its legal. right id like to explain that to a cop.
Old 02-28-2009, 06:39 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Cops in VA will pull you over for just about anything. PA cops are almost as bad.
Old 02-28-2009, 06:44 PM   #9
Darb
Darb's Avatar
I think the audi ones are a cool white. Not really true blue.
Old 02-28-2009, 07:19 PM   #10
LEGATO``
LEGATO``'s Avatar
crap
well im screwed
whats the website to check the laws and regulations for all 50 states?
Project LEGATO
Old 02-28-2009, 08:32 PM   #11
josevenezolano
Drives: Toyota Yaris HB 2008
What about the Halos? My right halos are not working well, It's like the led was moved from they should be, you can see them on but they are not really bright like the left side. Do I have to open the headlights to fit this?
josevenezolano is offline   Reply With Quote
Old 02-28-2009, 09:26 PM   #12
Darb
Darb's Avatar
Legato, search "code of virginia" in google. Then 46.2-1020, last paragraph. They could also hit you with 46.2-1030 section B.
On an iPod now, so I can't cut and paste the links for you.
Old 02-28-2009, 09:32 PM   #13
Jerkratt
Jerkratt's Avatar
if u take the house off the car and flip it over.. there are 2 circular grommets.. with the white and black halo wires coming out of um... pull that out and u should see the LED and if u look inside u should see where its sopost to sit..if it does not get as bad as it says it will weatherwise ill try to get pics tomorrow.. i also gotta take pics of the radio and ac control trim for someone else.. 2 birds with one stone
Old 02-28-2009, 10:14 PM   #14
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
stay away from anything blue. the cool white that was thrown out there is your best bet as is the www.autolumination.com website....
Old 02-28-2009, 10:44 PM   #15
LEGATO``
LEGATO``'s Avatar
Legato, search "code of virgina" in google. Then 46.2-1020, last paragraph. They could also hit you with 46.2-1030 section B.
thank bro
that website is a little confusing to me, which ones would fit headlights?
Project LEGATO
Old 03-01-2009, 11:36 AM   #16
Jerkratt
Jerkratt's Avatar
click the link i left in post 5 brings u right to thr 194's
Old 03-01-2009, 03:07 PM   #17
LEGATO``
LEGATO``'s Avatar
oh okay
thanks
question:
are those the same size perhaps as these right here
Project LEGATO
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 02:44 PM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 08:34 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 09:30 AM
