Old 01-07-2009, 09:47 PM   #1
auxmike
auxmike's Avatar
Question Pics of my AFE intake install + questions
AFE intake, that is!
OK let's see the box first and what it contains
Old 01-07-2009, 09:48 PM   #2
auxmike
auxmike's Avatar
OK, the old HUGE intake box....
Old 01-07-2009, 09:49 PM   #3
auxmike
auxmike's Avatar
Finished product...
Old 01-07-2009, 09:52 PM   #4
auxmike
auxmike's Avatar
MAP sensor wire just reaches.
Now, the instructions don't address this sensor with the blue connector coming off it.
I ended up TyWrapping it to the tube.
Thoughts?
Old 01-07-2009, 09:59 PM   #5
auxmike
auxmike's Avatar
Final install again from different vantage points.
Likes;
Looks almost "factory", very conservative appearance.
Does'nt really scream till over 5000RPM
Good quality parts and finish
Not annoyingly loud in the car at all with windows up.
Works well with my TRD exhaust...
Dislikes;
Instructions can be a bit vauge, pics are B/W and kinda dark.
Ended up with 2 extra bolts and 2 extra washers. Why??
What the hell are you supposed to do with that loose sensor?
5/8" hose gets attached to 1/2" elbow on intake tube, hose too wide.
Expect to take OVER an hour to do this and TAKE YOUR TIME!
This kit is well worth the $170. It's not rice or boy racer looking and everything seems to stay in place after a few trial drives tonight. Everything fits nice and there is good attention to details, EXCEPT that sensor thing...
Old 01-07-2009, 09:52 PM   #6
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
nice! ive been considering it as well.
Old 01-07-2009, 10:12 PM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
hmm looks like i commented before you got done. anyways, i dont know what you do with the sensor though
Old 01-07-2009, 10:14 PM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
just strap it somewhere. thats what i did. it'll be fine.
Old 01-07-2009, 10:21 PM   #9
auxmike
auxmike's Avatar
Hey Poop,
I saw your YouTube video featuring this intake. Nice...
All you need now is to toss the stock exhaust!
Old 01-09-2009, 09:17 PM   #10
PETERPOOP
PETERPOOP's Avatar
Originally Posted by auxmike View Post
Hey Poop,
dude, where you been? I have a JDM Blitz Nur Spec S axleback. Check it out..
http://www.youtube.com/watch?v=HyPad-mHupo
However, once i'm boosted i need a catback set up and will be losing this axleback. If anyone wants to claim dibs on it when i sell it. ;)
Old 01-09-2009, 11:57 PM   #11
auxmike
auxmike's Avatar
Nice!
Looks like you had to sell your shoes to buy it, eh?
Old 01-08-2009, 12:18 AM   #12
So far, this is my favorite intake for the Yaris.
Old 01-08-2009, 12:31 AM   #13
ruimond
Drives: Yaris YR
This is a photo of the same intake installed in mine its the 1.3L version of the engine, but its the same anyhow. Mine was just straped on with the plastic tie to the intake hoseing. I saw one of your photos and you screwed in the bottom right part, i don't remember seeing my mechanic do that....i don't think there was a screw in bit on that right side. Haha.
Old 01-08-2009, 01:43 AM   #14
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
You could remove the sensorand bracket , and twist the metal leg on it 90 deg, then losen the top 3" hose clip side it under and do hose clip up again.
The Spare bolt (M6X30mm and 2 washers are used if you did not remove the orginal airbox mounting bracket,
theres a hole in the bottom of the AFE box that lines up with the bracket .
That's if you did not remove it ,when you removed original airbox .
Old 01-09-2009, 05:21 PM   #15
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
The Spare bolt (M6X30mm and 2 washers are used if you did not remove the orginal airbox mounting bracket, theres a hole in the bottom of the AFE box that lines up with the bracket .
The Toyota dealer must have removed that bracket when they originally installed my TRD CAI. I was wondering why I had so much loose hardware leftover.
Old 01-09-2009, 06:08 PM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Loose hardware for a loose unit
Old 01-09-2009, 06:17 PM   #17
kou
Drives: 08 lb
looking good, but i am so happy i bought the k&n short ram when it was $230 for some reason it is around $330 now, they must be crazy.
Old 01-12-2009, 01:36 PM   #18
nvidiaxtc
nvidiaxtc's Avatar
Drives: Black 2009 3Dr Hatch
AFE INTAKE
Can I put the 07-08 AFE Intake on an 09 HB?
nvidiaxtc is offline   Reply With Quote
Afe intake feed back required. 1NZYaris1 Performance Modifications 51 03-20-2009 07:25 PM
(for Doc Zaius) aFe intake on a Blitz'd engine LtNoogie Performance Modifications 23 12-15-2008 01:25 PM
AFE Intake on a Sedan??? CASTREX Performance Modifications 7 12-12-2008 12:27 PM
Amp install under the passenger seat questions.. MudBug In Car Entertainment + Electronics (audio / video / alarm) 19 06-06-2007 11:12 AM
