anyway of taking out the abs light bulb?
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
from the gauge cluster? maybe if it is not soldered in....
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
It's an LED, not a bulb, so you'd have to desolder it, or just pull the face off of the cluster and put a small piece of electrical tape over it.
I've also put a dot of permanent black marker on a surface mount LED's lens, to make it be not so bright, but still visible. |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 03:59 PM |
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 01:02 PM |
| xenon hid light bulb | lilman717 | Cosmetic Modifications (Exterior/Interior) | 7 | 12-19-2008 09:07 PM |
| The right fog light bulb exploded and cracked the lense | vacantj | DIY / Maintenance / Service | 1 | 08-01-2007 05:07 AM |
