Old 03-20-2009, 07:35 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Are these oil pressure readings within range?
I just installed a sandwich plate and oil pressure sensor. The oil pressure gauge is finally connected and I shot a video to show the readings at various RPMs.
I was wondering if others of you who have oil pressure gauges are seeing the similar readings. I've never had one so I have nothing to go by.
Thanks
http://www.youtube.com/watch?v=3XsfSoKuDxU
Old 03-20-2009, 07:38 PM   #2
totally normal. Might even show 90+ on cold start.
Old 03-20-2009, 07:49 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
looks good, commentry could show a little more urgancy ,
then you would sound you like fighter pilot
Old 03-20-2009, 10:35 PM   #4
CompanyXPaladin
Drives: 08 Yaris 5-speed
how did you install the pressure gauge? maybe a diy?
+1, please
CompanyXPaladin is offline   Reply With Quote
Old 03-20-2009, 11:32 PM   #5
LtNoogie
LtNoogie's Avatar
Ok, I'll work on it. Not really a DIY since I did not take pictures along the way but I'll kludge something up.
Old 03-20-2009, 11:46 PM   #6
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
1 install sandwich adaptor
2. run sensor wire inside the car
3. ??????????????????
4. profit!
Originally Posted by xnamerxx
you nailed it sir.
Old 03-20-2009, 11:49 PM   #7
LtNoogie
LtNoogie's Avatar
Hey Peter, don't mess up my thread!
Old 03-20-2009, 11:52 PM   #8
LtNoogie
LtNoogie's Avatar
4. profit!
Tamago, you're right but sometimes pictures help those who have not gone through it. Otherwise, I could have said the same for the supercharger...
1. remove the parts you don't need
2. bolt on supercharger parts
3. wire to ECU
4. boost and grin
Old 03-21-2009, 12:16 AM   #9
enough's enough, if some people cannot act like adults, they need to go away and grow up for a while.
Carry on...
Old 03-21-2009, 12:17 AM   #10
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
is sandwich plate size is 20mm 1.5thread just wondering? And, it should be 20 - 80 in range.
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-21-2009, 12:19 AM   #11
LtNoogie
LtNoogie's Avatar
This is what I used.
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
Old 03-21-2009, 12:28 AM   #12
White Yaris
Broke Tuner
Drives: White Yaris
ah, thank you. And have fun with your fancy gauge and sc
Old 03-21-2009, 12:38 AM   #13
LtNoogie
LtNoogie's Avatar
I'm putting together a DIY. It should be up in a couple of hours.
Old 03-21-2009, 01:28 AM   #14
CompanyXPaladin
You rock.
Old 03-21-2009, 01:35 AM   #15
YarisSedan
Drives: 08 Yaris Sedan
I want to get one of these to go with that mod you did. And mout it behind the steering wheel for a oem look. And get a oil pressure oil temp and coolant temp gauges.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Oil pressure light on AlanSRT4 DIY / Maintenance / Service 22 06-27-2009 10:20 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
oil pressure sending unit yarissz DIY / Maintenance / Service 0 11-02-2006 07:49 PM
