Old 03-18-2009, 10:31 PM   #1
jouna
jouna's Avatar
Drives: jdm yaris sedan
Question how am i doing so far??
i have a 09 black yaris sedan manual tranny i have 2 1/4 straight pipe i have the manual cut out in the middle of the car ''sounds like an xrs' , i put a 10k potenciometer , amk header, 3'' cai made with pbc pipes their painted black lol,took out some hoses so the engine can breathe better took out the metal plate that is inside the throttel i was thinking prius pistons but they told me the tercel pistons even though theire flat pistons they make good compression in the yaris. what more can i put to run NA.
ps. at first i was a honda freak . im selling all my honda parts to put a corolla xrs engine. its gonna cost me 1300 with everything to put it to run 13's im in puerto rico
jouna is offline   Reply With Quote
Old 03-18-2009, 11:22 PM   #2
Puerto Rico FTW on modding cars. I gotta visit.
let's see, your goal is 13's: you did intake, throttle, header, exhaust.
Add an underdrive pulley and strip your car bare.
What do your wheels and tires weigh?
Get a larger throttle body.
Remove the A/C system completely. Down to 3 pulleys.
Run an electric water pump -- down to 2 pulleys.
Stiffen rear (or all) suspension so the car doesn't rock when you launch and shift.
Get a C-One rollstopper or (DIY) urethane your stock one.
TRD motor mounts.
Get a NITTO engine torque damper.
Design and fabricate an intake manifold.
Old 03-19-2009, 12:00 AM   #3
you forgot the MicroImage sticker
Old 03-19-2009, 12:36 AM   #4
xen555
xen555's Avatar
Drives: 3 DOORS LB
if you come to puerto rico u can see maybe a tercel with a rx7 engine fwd...
mmmm why not a yaris with a rotary engine ???
so much power for a motor with only 180 lbs. and the size of a 5 water gals.
xen555 is offline   Reply With Quote
Old 03-19-2009, 12:36 AM   #5
jouna
jouna's Avatar
lol thanks for the info. but i was talkin 13's with the xrs engine. with the yaris one im thinking about a good 14.6 or 14.3 the throttel of a 1zzfe will do good with the toyota performance manifold but where can i find the underdrive pulley and the nitto torque damper here in pr? or where can they ship one but not too expensive o and i have tein springs
Old 03-19-2009, 12:50 AM   #6
xen555
xen555's Avatar
Drives: 3 DOORS LB
mira yo le compre el pulley a NST que es un vendedor de aca y me salio buenisimo se nota la diferencia no tenes que pisarlo tanto y si lo pisas responde mucho mejor vale la pena me salio en 120 y pico el shipping solo lo cobra 10 dolares...
Old 03-19-2009, 05:24 PM   #7
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Aca puedes conseguir todo: www.MicroImageOnline.com
Old 03-20-2009, 04:17 AM   #8
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
PAsteles, gandule rice and beans and bacalao salad FTW!!
anonymous user is offline   Reply With Quote
Old 03-24-2009, 03:48 PM   #9
jouna
jouna's Avatar
gracias papito. deja poner esto en ingles pa q me entiendan ...where can i put the flowmeter in the pbc pice so the engine can turn on with no problems if someone has done this put pics or give me some good step 2 step rules to make it happen.
Old 03-24-2009, 03:55 PM   #10
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Welcome to YW, otro de Mi area :) Bayamon
hay que hacer algo pa encontrarnos en la fiebre a tripiar un rato
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-24-2009, 04:22 PM   #11
CASTREX
CASTREX's Avatar
Como ya te respondi en el otro thread... el problema no es donde ponerlo... es el problema es el diametro del tubo que tienes.
Con respecto a la ubicacion tan solo trata de dejarlo a 5-10 pulgadas no mas de Throttel body.
Old 03-24-2009, 04:25 PM   #12
CASTREX
CASTREX's Avatar
What is this potenciometer mod and were do you install it?
Is this the mod used to trick the car into open loop mode?
Wouldn't the ECU self adjust to that potenciometer variation?
This looks like the Ebay power chips...
Old 03-24-2009, 08:17 PM   #13
jouna
jouna's Avatar
the potenciometer is a 10k potenciometer when i turn it on ''it turns like a volume stick'' it sends information to the computer that the engine is -10 colder ''i checked it myslef with a obd2 thingy that reads everything in th engine''jeje and what it does is to send more fuel to the engine when you turn it on the COOL button appears ive been using it 4 a while and the ecu hasnt self adjusted the variation its suposed to run faster cuz it sucks more air and send more fuel
Old 03-24-2009, 08:18 PM   #14
jouna
jouna's Avatar
you can buy the 10k potenciometer in radioshack.. fuck ebay power chips that doesn't work 4 shit jaja
Old 03-24-2009, 08:24 PM   #15
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
PVC pipe is not a good idea for an intake
when PCV heats up it gives off a poisonous gas
Old 03-24-2009, 08:34 PM   #16
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You are just going crazy modding this thing What do you mean you took out some hoses? like vaccum lines ?
Old 03-24-2009, 08:34 PM   #17
PHXDEMON
PHXDEMON's Avatar
I had an ABS intake on one of my cars and it never caused issues
Old 03-24-2009, 08:53 PM   #18
Arkhangel
Arkhangel's Avatar
