Old 03-23-2009, 05:45 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
New car keys
When i bought the car they gave me a master key with some buttons on it and 2 valet keys,all 3 will open the doors and start the car.So i got another key made from the master key and it opens the doors but wont start the car,car turns over but wont start with this new keywhy?
Old 03-23-2009, 05:52 AM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
The two valet keys, they aren't just metal and have thick rubber or plastic on where you would grip them with your fingers when you turn?
I'm thinking your 3 keys have transponders (chips) in them. So throw that new one you made into your wallet incase you get locked out and go make one at the dealor if you want one that works.
Experiment: Use the new key, but hold one of your other keys beside it.
Old 03-23-2009, 08:39 AM   #3
Lafiro
Drives: 06 Yaris Sedan
What!????????
Old 03-23-2009, 08:51 AM   #4
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
It doesn't seem like the car would turn-over if our keys have chips in them. Maybe I'm wrong, but I had one like that on another car and I didn't get anything when I tried to use a copied key in the ignition.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 03-23-2009, 08:55 AM   #5
firebob
Drives: 09 yaris
I did not think that the 09 Yaris had the transponders in the keys. It was looked up when I had some keys made. I use a key that dose not have any plastic or rubber on it and it works just fine.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 03-23-2009, 09:00 AM   #6
If the car is equipped with the "Engine Immobilizer" it uses transponder keys. My 09 included it with the power package.
The easiest way to tell if a car has it and hence requires the transponder keys is to look for the flashing red LED on the left side of the dash, after you shut the car off. It is visible when looking at the car from outside.
The other way to tell is to look at the ignition switch - If the car has the Engine Immobilizer you will see metal trim around the switch. If it doesn't the trim will be plastic.
Old 03-23-2009, 09:01 AM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
all new cars sold in Canada since 2008 must be equipped with a transponder key.
Jambo101: one of the other key is a master key without remote. one is a valet key that will not open the trunk. the trunk can be locked by using a master key and turning LEFT (opposite direction than opening)
Old 03-23-2009, 09:10 AM   #8
firebob
Drives: 09 yaris
Ok I see now. I do not have the power package.
Old 03-23-2009, 06:20 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
Engine will try to start when fuel is disabled. Just wont start. Thats why it feels like its trying to turn over. Being engine is immoblized. Since it has a immobilizer? That immobilizes the engine but cutting off the fuel to prevent theft. Incase someone tries to steal the car and doesnt have the key that is keyed to the ignition. Which is why you have to buy the special key from the dealer have them key and code it to your ignition for it to work.
Old 03-23-2009, 06:32 PM   #10
rningonfumes
I think it's a matter of the countries. I know Canada gets some goodies we here in the states don't-- back then at least, don't know about 2009 cars.
Old 03-23-2009, 08:21 PM   #11
jambo101
jambo101's Avatar
Guess i got chips in the keys..Whats a dealer gonna charge me for a spare key??
Old 03-23-2009, 08:57 PM   #12
supmet
Drives: 2007 4 Door Yaris
I'm guessing a LOT, but not sure. If they quote you something outrageous you should be able to find a locksmith that works on transponders to make you one for cheaper.
Old 03-24-2009, 10:14 AM   #13
IllusionX
it's something like 127$ for a blank with remote.
Old 03-24-2009, 03:27 PM   #14
Most automotive locksmiths will have the equipment to program a new transponder key, and will typically charge far less than a dealer. The uncut transponder keys for the Yaris are about $30, plus cutting and programming.
Dealer list for the key is about $50, but the one that I checked with wanted over $100 including cutting and programming.
The part number for the 08 and 09 Yaris transponder keys is: 89785-60160.
Old 03-24-2009, 05:37 PM   #15
IllusionX
cscott, did you check the one with the remote??
Old 03-24-2009, 08:15 PM   #16
The one with the built in remote is 89070-52850 for 08 and 09. The dealers get over $200 plus whatever they charge to cut the key, teach the remote entry system, and program the transponder.
Old 03-25-2009, 09:37 AM   #17
IllusionX
thanks.
it's quite a bit cheaper without a transponder chip in the remote/key.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
