![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Cruise Control
Am thinking of adding this to my 2009 Toyota Yaris hatchback; anyone done this? Did you go to the dealership? How did it work out for you? The cost?
![]() Drives: 2008 yaris lb Join Date: Nov 2008
Yes I installed my own in a 2008 HB. purchased from sparks toyota (http://trdsparks.com/displayparts.ph...&parts_id=1947) installed pretty straight forward. works great. but they only recommend for auto trans?
![]() ![]() ![]() Drives: 3-door liftback blazing blue Join Date: Oct 2006
I put one on my 07 yaris manual works fine.I saw a new 09 yaris manual trans at my local toyota dealer had factory cruise control
07 yaris LB 5-speed blazing Blue 07 yaris LB Auto Bayou Blue rostra cruise control oem style foglights 96tacoma 4x4 xcab I4auto Weathertech vent visors Scan GaugeII |
I added the CC unit from TRDSparks to my 2008 auto LB...... not too bad to install but it does hurt your mpg if you are into saving gas.
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
#5 | |
col_blu
Drives: 2008 Red Yaris 3-door A/T Join Date: Oct 2008
Gas Mileage
With an AT, I've always gotten better mpg w/ cruise. I had mine installed by dealer (they jobbed it out) and it hss a 3 yr/36k mile warranty. Its cost $200-$250. Mine cost $450 installed.
![]() Drives: 08 3 dr Hatchback blue Join Date: Jan 2009
Re cruise control install on an 08 Auto HB
Did the kit from sparks come with instructions? How hard was it. I'm looking at buying it. Thanks, K.C.
KCSAILS |
![]() ![]() Drives: red Liftback Join Date: Aug 2007
I orginally purchased a Rostra(?) DIY cruise control, but when I went to install it...I realized that I just didn't have tiny enough fingers (and body) to do the installation. My local Rostra dealer allowed me to return it for refund. Went to the dealer and they installed the exact same brand unit. But the first unit they installed happened to be defective...it took the dealer about six hours to finally figure out that the unit had to be totally pulled back out! The second unit has worked fine. (If I had installed the unit myself...I think I would still be working in it if it turned out to be defective).
Not only that, the dealer warrantied the cruise for 36K/3yrs. He stated that if anything beneath the dash had gone defective and they found a DIY cruise installed...he wasn't sure if Toyota would consider the warranty void. Before the cruise installed, I usually got about 38-42mph when driving continuously on rural highways (no stop and go)...with the cruise engaged, I almost always gain somewhere between 2 and 8 mph! With no winds and flat road...I have been getting between 45-52mph with the cruise. Shutting off the cruise, I cannot hold the accelerater as smoothly as the cruise and my mileage drops noticeably. I use a ScanGaugeII to continuously monitor my mileage. |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Do yourself a favor - print out and use the color instructions from Rostra's website.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
![]() Drives: 2008 Liftback S Join Date: Oct 2008
I tried calling a few dealers in my area before Christmas to ask about the cruise control for my 2008 Yaris LB (5 speed) and none of them found the parts in their system. I guess if I want cruise I have to buy the kit online and do it myself.
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
I did a DIY Rostra unit on my hatch a year ago. To really get good mileage you have to use the buttons to control throttle. I use it a lot hyper-mile'in and consistently get 43 MPG commuting. Costing down to a light the trick is to be able to re-engage the cruise on a red-to-green transition before the speedo falls to 25 mph. It won't lock-in in 5th below 25 mpg. When luck smiles I make it the full 16 miles to work with out pushing in the clutch or down shifting out of 5th. Rostra limits the acceleration rate to a value easy on gas.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
2008 Prht Miata Red
Drives: 2009 3D 4AM PWR Pkg, Yel Jolt Join Date: Feb 2009
My Rosta CC does not work
I bought a CC from TRD Sparks and the on and off light works, the electric gas pedal works, I'am able to drive the car and it works as it did before I installed the cruise control. It took about 2 hours for the install, but, it doesnt work completely.
TRD Sparks is a Rosta unit. Except the cruise control will not hold the speed. Tried it on the street doing 40MPH or faster, & on the freeway at 65. When you press your set button can you hear the relay click? I have wired many other cars and feel confident with doing wiring and adding upgrades. I wonder if it is bad out of the box. G |
2008 Prht Miata Red
My CC works now
A wire was making intermittent contact, fixed problem.
TRD Sparks is awesome, They helped out over the phone and will do what every they can to help. A big thanks to Shawn & Ken at TRD Sparks G Last edited by westgl; 03-12-2009 at 09:49 PM. |
Drives: Yaris RS Join Date: Apr 2009
Canadian seller ??
Hey!
Good to know that cruise control exist ! Any place to buy it in Canada or simply order from TRD ? So this will work fine on my yaris 5 speed ? Thanks !! DA |
| Yaris.. Cruise Control. | peanut | New YARIS Purchase Forum | 28 | 11-26-2017 07:17 AM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| Cruise Control in the LB | RobotMan | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-30-2007 03:43 PM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 04:21 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
