Old 04-10-2009, 09:55 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Rough Automatic Shifting
My 2009 Yaris has developed rough shifting. Im not sure if i just have not noticed it before, or if it was always like this. What happens is when it goes to shift i can feel it A LOT. And its almost as if its having a hard time shifting. Its just rough and loud.
Also, around 20 MPH my yaris basically pushes it self forward. ( i dont know how to explain this well.)
Like ill go from 30, and take my foot off the pedal, and it will go down to 20 and its almost as if its shifting (even though im not accelerating) and it will basically feel as though its pushing my yaris faster.
Is this normal or is it something i should get checked out?
Twistoffate0817 is offline   Reply With Quote
Old 04-10-2009, 11:38 PM   #2
MadMax
MadMax's Avatar
How many miles do you have on your car? How long have you had it? Are you sure it just isn't the touchy throttle?
I would also advise trying to drive another auto to see if it is the same way. If you are new to the Yaris then it may just be that you haven't gotten used to it. If you aren't, then I would most definitely have the dealership check it out while it is still under warranty...
Cheers! M2
Old 04-13-2009, 02:46 PM   #3
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
You know, I think this is what I feel with my car but I assumed it was just because its a... 'lower end' car. The only other car I've driven is a Nissan Maxima (really old though) but I think it had smoother shifting. I feel like there's a jerk whenever the car shifts (I assume thats what the jerk is, I am so new to this, I'm not even if what I feel is when the gear shifts)
With my old car, I don't think I even noticed when it shifted, and I def do with this one. I'm just assuming its because its an 'economical' (/cough cheap) car..
wiirenet is offline   Reply With Quote
Old 04-13-2009, 02:48 PM   #4
supmet
Drives: 2007 4 Door Yaris
If you ever can feel your transmission clunking, you need to take it in...
My car has 67K miles on it. I drive 60% or more in hilly cities. I have Dexron transmission fluid in my car which is SPECIFICALLY recommended AGAINST in a toyota TSB.
My car always shifts perfectly smooth
Old 04-14-2009, 12:32 AM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I bet it does this when the engine is cold? Until the engine reaches 180 deg F, it won't up shift to fourth. When going slow, the idle is much faster than when warmed.
Old 04-14-2009, 12:46 AM   #6
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
i have this kind of feeling all the time.......but i dink it's how it is...
Yawesh is offline   Reply With Quote
Old 04-14-2009, 10:57 PM   #7
Twistoffate0817
ok im glad to hear that its not only me..and i have found that after driving it for awhile the shifting does get less noticable then when i first start it up and go in the mornings.
I will just keep an ear out for things and if anything still bothers me i guess ill take it in to be looked at.
Old 04-15-2009, 03:43 PM   #8
wiirenet
wiirenet's Avatar
Okie, after this post I started paying attenion more when I'm driving- this doesn't happen all the time, just once in a while. Most often it happens when I'm speeding up fast to get on the highway or when I'm already on it and have a chance to speed up fast.
Old 04-15-2009, 03:45 PM   #9
SailDesign
Drives: .
The easiest way to get rid of this problem for good - buy a stick-shift car......
Old 04-15-2009, 03:48 PM   #10
wooverstone8
wooverstone8's Avatar
+1
rough surface... abdallah380 Wash, Wax, Detailing, Exterior Repairs 6 02-16-2009 02:09 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 07:02 AM
Automatic Choke Stuck Rua General Yaris / Vitz Discussion 9 02-22-2007 07:57 PM
5spd vs automatic m-arco General Yaris / Vitz Discussion 16 12-14-2006 06:32 PM
