Old 03-23-2009, 10:34 AM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Another S/C'd member worried about his AFR
I am posting the dyno printout for another Blitz S/C'd forum member who is worried about his AFR. His dyno technician would not perform a third pull because he did not want to be responsible for damaging this member's engine due to the lean readings.
Without access to a ScanGauge to indicate ignition timing, I do not know if he is facing a problem or not. He is not experiencing any pre-ignition due to the use of octane booster but that gets to be an expensive practice.
Largeorangefont, he has specifically asked for you to weigh in on this. I can post the HP curve if that would be helpful.
Thanks.
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 12:10 PM
