Drives: 2009 Toyota Yaris S 5-Door Join Date: May 2009
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch
Tried to turn OFF the daytime running lights by removing the relay box under the steering column. When i remove/unplug the box the lights then don't come ON(GOOD), but my fog lights then don't work. Is there a work around??
![]() Thanks!! |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
find the orange wire on the harness you pulled off the light module, then connect it to any metal frame as the grounding.
wire tap is works too . |
| Day Time Running Lights | rdobiash | DIY / Maintenance / Service | 4 | 01-23-2009 12:36 AM |
| how bright are the daylight running lights? | anon | Canada | 11 | 10-26-2008 08:38 PM |
| Daytime Lights | NimbleYarisOwner | General Yaris / Vitz Discussion | 17 | 08-24-2007 10:07 AM |
| Daytime running lamps suck | Indianspringsaz | General Yaris / Vitz Discussion | 37 | 07-27-2007 05:29 PM |
| Does the Yaris come with............. | Driver | Cosmetic Modifications (Exterior/Interior) | 7 | 08-21-2006 01:06 AM |
