Old 05-03-2009, 09:16 PM   #1
Liu997
Drives: 2008 Red Yaris LB
Tach ECU wire, auto
I was just installing a tach on my yaris when, I realized that I didn't have the greenish blue wire on my OBD II port. I am guessing that an auto has it on a different wire. Can someone tell me which one is it?
Liu997 is offline   Reply With Quote
Old 05-03-2009, 09:44 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Your best bet would probably be to swap to a manual transmission so you actually utilize a tach
Old 05-03-2009, 10:13 PM   #3
Liu997
no one knows, or have installed a tach on an auto?
Old 05-03-2009, 10:24 PM   #4
Same position, but on my 09 it is beige:
Old 05-05-2009, 08:20 AM   #5
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
^ I used that same wire and it works great.
Old 05-05-2009, 10:37 PM   #6
Liu997
What should I set the tach to, I am guessing 4 cly. But when I reved it up in neutral, it went to 7K rpm. Just thinking thats kinda odd.
Old 05-05-2009, 10:38 PM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
it does on mine too. why do do you even need a tach for an auto?
Old 05-05-2009, 11:49 PM   #8
Liu997
idk, just like to see whats happening and or if the auto is shifting dumbly
Old 05-06-2009, 01:44 PM   #9
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
lol Im driven an auto and I put in a tach too
we may not need it for shifting but its still nice to see the RPMs for what ever reason. In my last car (also an auto) it had a stock tach, At one point I started having this misfire that would only occur between 3700 & 4300 rpm. It was a dead give away when I googled 'misfire' and the said RPM range. if it wasnt for the tach I wouldnt have been able to diagnose it myself, so IMO, tachs arnt just for shiftin.
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
