Old 05-01-2009, 06:22 PM   #1
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
Exclamation spring install. Help needed asap!
Today I figured I install my tanabe df210s today. weather isn't on my side and is on the verge of a downpour, but I'll work in the rain if I half to.
I've ran into numerous problems just taking off the front stock suspension. I started on the driver side and ended up having to take the wiper assembly out and all the metal shrouds due to lack of tools I suppose.
Anyways, I cant seem to get the top strut nut off, at all. Won't budge. Everything I have tried hasn't worked. If I keep up trying I'll end up striping everything out. Any help would be greatly appreciated!!
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 05-01-2009, 06:46 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Have you had a read of this .
Old 05-01-2009, 07:11 PM   #3
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
man I have read both DIYs. I see a good impact being the only way. Both DIYs said they did it with a open box end and a 6mm hex. But my bluepoint wrench couldn't get that angle even with the wiper assembly removed and the black shroud. Both the wrench and hex were slipping and SAE stuff wouldn't fit properly either. I can understand how to do it, but I can't figure how the fuck to do it, lol.
I have given up today, but if anyone has any tips on how to do this easily please let me know.
Anyone in central Arkansas on here? Know of anyone with an impact or maybe a more vast selection of tools?
Old 05-01-2009, 07:24 PM   #4
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Step 14 =
Old 05-01-2009, 07:29 PM   #5
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Make sure you aren't trying to remove the spring top nut, it isn't supposed to be removed until the strut is out of the vehicle. Remove the 3 smaller nuts. I think the larger center nut might be spinning the strut rod anyway, so it might not back all the way off. Either way, you DO NOT want to release all that spring tension while the strut is still on the car. Very bad. If you follow the DIY, the Yaris struts should be one of the easiest removals out there. The rear is even better.
Old 05-01-2009, 07:40 PM   #6
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
You know, you just may be right! Can anyone clarify this, as it's not really that specific in the DIYs. Are the two nuts, one holding the top of the strut in place and one holding the spring. This is how I assumed it was. It very well may be only one nut, and it's hold the spring.
You know, I never thought of that! Let's make me feel stupid shall we lol
Old 05-01-2009, 07:57 PM   #7
It's one nut.
Probably. A 17mm OFFSET box wrench will get that nut off without having to remove the shrouding.
Old 05-01-2009, 08:08 PM   #8
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Yeah, no offset wrench, but do I need to loosen the nut first, or will it come out without? I removed the shroud so I could reach it but it would not budge.
Here's a quick list of what I did
Took wheel off.
Took nut off of sway bar link.
Took off both lower strut bolts and nuts
Took off wipers, assembly, and shroud
Took off brake line nut
Took off dust cap on top of strut (a 17mm nut stared up at me and laughed )
Here's a quote from the "Tanabe" DIY:
Once all is removed, the only thing holding the strut/spring assy., is the upper nut.
...Leading me to assume there are two nuts.
Old 05-01-2009, 08:23 PM   #9
ozmdd
ozmdd's Avatar
[QUOTE]It's one nut./QUOTE]
Crap. I mixed-up my Yaris w/ my Miata. I've changed struts/spring on both in the last couple of months. Sorry about making things even more confusing.
Old 05-01-2009, 08:25 PM   #10
ozmdd
ozmdd's Avatar
Are you holding the shaft with an allen wrench while you loosen the 17mm with an open-ended wrench or offset box?
Also, you can get an affordable/decent offset box wrench set (metric) for $10-$15 at your local Auto Zone or Wally world. Well worth the investment.
Old 05-01-2009, 08:40 PM   #11
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Yes. 6mm. Started to slip before it broke loose (allen key not wrench).
Old 05-01-2009, 08:40 PM   #12
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
need to take off the top nut bolt first to remove it...u could buy a cheap $30 lighter operated impact wrench at kragen or autozone...03z33 and i were having the same problem yesterday and he decided to buy those cheap impact wrench...sucker works like magic..
Old 05-01-2009, 08:44 PM   #13
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Thanks!! Question about impact: Pneumatic or Electric?
Old 05-01-2009, 08:42 PM   #14
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
If there is only one nut (assuming it holds in the spring) do I need to loosen it to remove the strut assembly from the car? At which then I'd compress the springs for an easier removal of course.
Old 05-01-2009, 08:46 PM   #15
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Oh and I have a 18v Makita Impact Driver. A buddy has it right now. It puts out about 100ft/lbs of torque I believe. Think that will get it done?
Old 05-01-2009, 08:51 PM   #16
Malaya1221
Malaya1221's Avatar
12v electric impact wrench
struts have two bolts...one on top that holds a plate to the car and the second one will b the one holding the spring down...we did not decompress the springs...we held the strut down pointing to a safe direction and used the impact wrench....have fun!
Old 05-01-2009, 09:01 PM   #17
frownonfun
frownonfun's Avatar
i was having hell getting that nut off also... it broke loose fairly easy with some quick taps on the wrench with a rubber mallet. i say taps but really i had to hit it pretty hard. just make sure the wrench is on good.
Old 05-01-2009, 09:02 PM   #18
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Thanks again!
Know the torque rating of it?
That's how I installed my skunk2s on my old prelude lol! I figured I'd go the safe route since I'm alone.
I'd like to thank everyone for the fast responses. I was a little worried about the speed as of my last post of my exhaust (been only a few posts and it's been up over 24 hrs lol)
I will attempt once again tomorrow unless weather says no. If I run into any problems I'm sure everyone will hear from me again. Glad I decided to tackle the hard part first lol
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 12:47 PM
spring install help asap! DELETE tristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 02-18-2009 02:30 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
