Old 05-18-2009, 11:53 PM   #1
codymclelland
Startin small.
91 Grade fuel?
A friend of mine decided to try putting 91 grade fuel in his Jetta that is graded at 87. After about 20 miles, the computer adapted and the timing advanced and now it roars! Would the same be true of the Yaris? Would the computer adapt or would this somehow be bad for the engine?
| 2007 S | Debadged | Toytota Emblems, Grille & Chrome Trunk Applique Plasti-Dipped Black | Radio Console Plasti-Dipped Black |
PLANS:| AFE Short Ram Air Intake | Quickshifter | Grounding Kit | Gauge Cluster/Radio/AC Console LED Change to Blue | Window Tint |
codymclelland is offline   Reply With Quote
Old 05-18-2009, 11:56 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
some say yes and others say no , me i say yes it will and does ,
but i only have a 1.3 not the 1.5so try it and see.
Old 05-19-2009, 12:42 AM   #3
severous01
umm....no
simple fact that the ecm controls the timing, not the fuel. timing is pre-determined to be whatever manufacture programmed into the ecm. the one and ONLY thing that will change the timing other than throttle is the knock sensor. and this will retard timing, not advance.
now...if you have a programmer, that's a different story because you're changing ecm programming.
you need to do a wiki search on octane or fuel ratings. grade of fuel does nothing unless you're supposed to be runnin 91+ and ur not.
Old 05-19-2009, 12:43 AM   #4
Nope, it won't. I try to run premium (Chevron) at least once a month for cleaning purposes. Never noticed any changes in performance. Simple fact is that if your car can't appreciate the added octane, it won't do anything with it.
Old 05-19-2009, 12:48 AM   #5
Deltasix
Deltasix's Avatar
Drives: '07 Liftback: Work in Progress
Send a message via AIM to Deltasix
Do you have any info to back up the fact that this actually cleans out the system? Just wondering, because I've seen a lot to the contrary.
As to the original question, I've filled my tank up with 93, no difference whatsoever.
"The basis of optimism is sheer terror."
Deltasix is offline   Reply With Quote
Old 05-19-2009, 12:51 AM   #6
I actually don't, I'm just going by brand name (I did an experiment with Safeway vs Chevron with my GTI, but using 87 for both, and got horrendous FE with Safeway). But then, there are my Suby friends who swear against Chevron because it actually messed up their engines. Who knows, may be those "cleaning additives" in Chevron are bad for boxer engines?
Old 05-19-2009, 12:45 AM   #7
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i run 91 in my tc and its rated for 87 and it actually runs better on 91 then on 87 same as my yaris i run 91 on it to it runs better then on 87 it does help a little bit and it does change anything better gas does make a difference but a very little difference but some notice it some dont
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-19-2009, 05:22 PM   #8
severous01
it's all in your head or you got problems that need to be fixed with pre-ignition...or knock
read:
http://en.wikipedia.org/wiki/Octane_rating
http://www.answers.com/topic/octane-rating-1
http://www.associatedcontent.com/art...ly.html?cat=27
http://www.rpmeng.com/octane.htm
Old 05-19-2009, 01:10 AM   #9
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
omg this was posted in general which one to use 91 or 87 lol i use 91 all the time hands down
Aothachos is offline   Reply With Quote
Old 05-19-2009, 06:22 PM   #10
battleversiontc
can you prove it not unless theres a dyno chart plotting two different octanes then all the words that someone writes just means bullsh!t to me not unless is proven in numbers on the same car with a base of 87 octane. and it aint in my head the cars performance is better and im know for a fact i dont have problems with my tc or the yaris. if a car that is rated for 91 octane puts 87 octane in there is a performance decrease as well as knock but the knock sensor will pick that up and the ecu will adjust timing to prevent the knock so there for 87 octane upgrading to 91 octane in a car rated for 87 performance will increase such as accleration because timing will then advance as the sensors will adjust to the change of the c02 levels in the exhaust there for increasing performance. if there was no need for higher octanes we wouldnt need em and every car would use the same octane waste money and time to develop different octanes if thats the cause its all in my head sorry maybe you just getting alittle to much sun in texas
Old 05-19-2009, 06:44 PM   #11
Here you go: http://www.youtube.com/watch?v=dDHwC...eature=related
Very good experiment comparing different octanes, and proof that premium gas will not gain you anything in terms of performance.
Old 05-19-2009, 10:11 PM   #12
codymclelland
Startin small.
So is this simply because the Yaris is an economy car? Does the ECU simply not recognize the higher octane fuel?
Old 05-19-2009, 10:13 PM   #13
I really cannot answer this knowledgeably, but perhaps.
Old 05-19-2009, 06:55 PM   #14
battleversiontc
if you watched the very end portion he did say that higher octane will give you more performance and 1 out of three cars never made performance so you just proved me right
Old 05-19-2009, 07:01 PM   #15
wheres the proof when two of those cars are turbod and they made more horsepower on higher octane then reccomended so you just proved me right
Yeah, but our Yarii (at least mine) are not force fed. It would fall under the same category as the Clio, purely made for economy. "You guessed it, 81 brake horsepower."
I was never claiming that premium gas will not make any difference on higher end, performance oriented cars. But suit yourself, keep spending more for premium gas. And if you really want to prove us wrong, conduct the same test that they did.
Old 05-19-2009, 07:07 PM   #16
Yeah, those other cars are PERFORMANCE cars, not economical cars. I don't know about you, but I don't consider our Yarii performance cars. We're basing this thread on the Yaris, an economical car. And as in that video, the economical car did not make extra power with higher octane gas, so you're proving me right.
Old 05-19-2009, 07:12 PM   #17
http://www.yarisworld.com/forums/sho...hlight=premium
Old 05-19-2009, 07:15 PM   #18
But hey, it's not our money. Do what you like. If you feel a performance gain, good for you.
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
Mini v. sedan = injury. No duh. Is this news? jess General Yaris / Vitz Discussion 48 04-17-2009 07:46 AM
Any body have good data on the Yaris fuel system? LtNoogie Performance Modifications 9 03-26-2009 09:01 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
