power steering auto shut off
there are this signs that be4 the incidence occur... headlamp and odometer getting dimmer and start blinking... the radio set starting to go off and on a few times... after that the power was so hard that i cant hardly turn... it is so dangerous if i was taking the corner... do u guys know probably wat is the problem... i suspect that the circuit is having the problem...
#2 | |
If I had to guess, I'd say the problem is with your alternator. |
Drives: yaris Join Date: May 2009
Since we have electric steering (no hydraulic steering system, but an electric motor that assists in turning), and since the failure is related to other electrical failures, and since the symptoms you describe, I would almost certainly say the alternator. Take this from a guy who used to have to buy crap used cars and drive them until they gave out. I have had dozens of alternators go out, and that sounds like it. If it is under warranty, go get a free new one at the dealer!
P.S. I always wondered if the electric motor ran off of the alternator or was a separate system, but I guess I answered my own question lol. By the way, do any of you guys know where the steering electric motor is if I look under the hood? I always wanted to see how big it is just out of curiosity. Personally I LOVE electric power assist. It beats this complex system of tubes and liquids lol. |
thks for the info... im not sure where the motor located at cause im a noob to car... haha...
SIPNDEW
if i had to guess, the motor is probably made into the rack.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
![]() I always thought the power steering "turned off" when you were going faster than 10 or 15 mph. You certainly don't need it after that. I wonder if a lack of power somehow seizes the motor up. But...
SIPNDEW
well if you alt. or batt. is failing and not putting out the required voltage, the electronics stop working. i would say its a batt or alt problem
