squeaky stick
No sure really what to do about this. Its probably just something a lil grease could fix but I wasn't sure. So for about 2 weeks I've been hearing this squeak when I shift. I couldn't tell if it was the clutch peddle or something under the hood. Finally yesterday I was sitting at a red light and started playing around with the gears. And noticed the noise. It squeaks when I put a lil lateral pressure on the stick wile shifting up or down. Is this an indication of something more serious or just that it needs some grease to lube it up.
Sorry if this had been asked already. And any feedback would help. Ty
Bang those gears Last edited by A-tron; 06-02-2009 at 03:22 PM. |
it's not a clutch noise? generally the squeak is from a dried out pivot point for the clutch fork.
have you been "banging those gears" a lot? you may be due for a gear oil change
Lol I do shift in the higher rpms often. But yeah its not the clutch for it makes no noise when depressing the peddle. Just when the stick is moved. Its only if I "drag" the stick along the boundaries of the gear.
Ill try changing the oil and see if that helps. Diy forum here I come.
Bang those gears |
#4 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
no...I don't think it needs gear oil changing. Mine squeaks, but it doesn't bother me. I've been trying to search for a particular thread that addresses this issue by lubing some part on the tranny.
Can't find it so far, it's buried under mountains of threads asking about this stupid squeak. ...should have been Stickied. EDIT: Found it! Here you go: http://www.yarisworld.com/forums/sho...ighlight=shift
Ty man that thread saved me some cash.
Bang those gears |
| Stick On or In Channel Visors | schreck | General Yaris / Vitz Discussion | 20 | 04-22-2009 07:27 PM |
| A stick shift without a tach? | dulcidude | DIY / Maintenance / Service | 29 | 01-07-2009 08:05 AM |
| Is the 2006 Yaris Manual stick leather wrapped or not? | hoahmaru | General Yaris / Vitz Discussion | 21 | 10-30-2008 09:14 AM |
| I'm gonna learn stick just for the Yaris!! | YarisBlazer | New YARIS Purchase Forum | 24 | 09-14-2006 09:17 PM |
| 3 Door Stick coming to Hendersonville NC | Search | General Yaris / Vitz Discussion | 5 | 04-20-2006 11:11 PM |
