Old 07-06-2009, 01:22 AM   #1
rkvin21
Drives: 2012 Toyota Yaris SE
Wet float bearings
What is bad about using Wet float bearings(oil cooled journal bearings?)? I know that it is best to have ball bearing but to what point are they better. I have seen cheap t3/t4 turbos that have wet float bearings. Ik the saying you get what you pay for but it would be nice to get a turbo for less than $500. I did a search in google and came across a forum about using ebay turbos. Pretty much it has been a hit or miss with them and it is unclear as to what caused their turbo to fail to tell if it was only the turbo itself being poorly manufactured or not. I also came across a site that sells turbos and does turbo rebuilds http://www.blaastperformance.com/index.php.
rkvin21 is offline   Reply With Quote
Old 07-06-2009, 01:38 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Nothing bad about regular journal bearing turbos...
Actually the Journal bearings will usually last longer than a ball bearing unit...
The Ball bearing units have the benefit of a quicker spooling time... but you can address spooling time by making sure you get the right size turbo for your application.
Don't even look at the ebay chinese turbos. You can get a good quality turbo for less than $500.
Look for Impreza take offs... Lots of Subaru folks upgrade to a larger turbo after just a few thousand miles on the OE unit.
Tamago here used a turbo out of an STI with good success.
Another good candidate can be a K03 turbo from the 1.8T Volkswagens.
I've seen them new for less than $400...
Old 07-06-2009, 03:09 PM   #3
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
the STI turbo (VF39) was to full boost by 3800RPM which IMO is spectacular, given the displacement of the 1nzfe vs the EJ257
Originally Posted by xnamerxx
you nailed it sir.
Wet Okole RS/S seat covers!! w/pics! PaidTimeOff Cosmetic Modifications (Exterior/Interior) 2 12-04-2008 07:53 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
Cold & Wet - mixed by tekmoe tekmoe Off-topic / Other Cars / Everything else Discussions 4 06-18-2007 09:50 AM
