![]() Drives: 08 Yaris hatchback Join Date: Oct 2011
hey everyone, this is my first time posting. i noticed a body kit for the LB that had a small retangle cut in the front bumper part, right in front of our air filter box. i also saw the same retangle cut in a body kit for a Nissan 350z also right by the filter. i was wondering if this cut alone could add any performance on a N/A stock yaris?? or what would even happen if we took a roto-drill and made a cut through the bumper like that to allow more air to the intake? thanks!
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I doubt it would make much of a difference. More air is always nice, but probably isn't going to be noticeable IMO.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
It will make a difference if you route a tube from there into the airbox. That would be a type of ram air intake.
![]() ![]() ![]() Drives: '12 Yaris LE Lagoon Blue Mica Join Date: Feb 2012
I'm sure that is what it's for.
Good luck guy! |
#5 | |
Get an intake first, worry about routing air to it second. On my AiM dash I can monitor air inlet temps. Using a modified K&N I typically see temps about 10 degrees higher than ambient. The last race we ran it was in the 70s the entire time, and that is with no ducting, just using the air that comes around the side of the radiator.
Jason, are you open underneath the engine bay, or do you have that covered in some way?
#7 | |
I cant recall if the AC condenser would block this on a stock car.
my recollection is that the a/c condenser is directly in front of the radiator, and somewhat to the passenger side. Could be wrong though, and can't check.
![]() ![]() Drives: yaris Join Date: Nov 2011
on the 4 door you have more room on passanger side than you do driver.
thanks for all the insite eberyone! I'll pick up a nice intake soon, then I'll give it a try and tell you guys if it helps at all. thanks again.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
My stock intake sees just above ambeint temps while moving.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| Tags |
| cut front bumper intake |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| Performance? | chrisj | Off-topic / Other Cars / Everything else Discussions | 9 | 10-16-2010 05:14 AM |
| December at TWM Performance! | TWM Performance | TWM Performance | 17 | 01-08-2010 09:14 AM |
| >>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< | TWM Performance | TWM Performance | 0 | 12-24-2009 10:21 AM |
| Black Friday SALE from TWM Performance! | TWM Performance | TWM Performance | 1 | 11-27-2009 11:46 AM |
