Hey all. I have a Pioneer Avic D3, and when I had it installed back in 2007, the guy placed the GPS antena inside the car. Right on top of the dashboard. I've recently tinted my windshield and just discovered the hard way, that the tint actually blocks the GPS Satellite signal. Now, I have to somehow place my antenna outside the car in order to get signal. My question now is. Are there any ideas on how to do it, without making a mess? All suggestions are welcome!
GioBatera
#2 | |
Go under the hood through the large bushing behind the fuse panel, and then mount it to the bottom of the plastic cowling at the base of the windshield. |
Parallel Parking Pro
Change your tint to something that is non-metallic, or you can cut a small corner off the top or bottom of your windscreen tint to allow your GPS antenna to peek through. If your GPS supports an auxiliary connector for an external antenna, you can run a wire through your firewall and to the outside.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#4 | |
GioBatera
#5 | |
GioBatera
the glass should not block the signal enough to cause issues..
It actually does. I check the signal strengh and it's one bar and it shows that I'm in streets that I,m not even at. The minute I place the antena out of the window, everything works 100%
GioBatera
Sounds like you have all the necessary bits, well the best solution would be to go back to the guy who installed it back in 2007 and get him to install the antenna properly outside of the car. Unless you're intending to DIY.
#9 | |
GioBatera
take it to Andy
Despising the fact that he's a little too far from me, that might be my best option. At least I know that I can trust him with my ride. I'll send him a text.
GioBatera
I spoke to a friend that I met thanks to TAMAGO. He works for the Toyota of Hollywood, FL and he'll do it for me tomorrow morning. I’ll keep you posted as far as how it came out.
GioBatera
My radio stopped getting signal after i got my tint. I think cause our rear glass has the antenna incoperated into it.
All done.......thanks for all the help and MODS..Please close this thread!
GioBatera
boydstir
WINDOW TINT WILL HINDER THE SIGNEL STRENGTH !!! ANOTHER PLACE TO MOUNT IT IS DEAD CENTER OF BOTTOM OF FRONT WINDOW INSIDE INFRONT THE YOUR GUAGE CLUSTER THERE IN SMALL SPOT DEAD CENTER OF THE DEFROSTER VENT YOU CAN SECURE IT THERE THAT SPOT WORKED FINE FOR MY GPS ANTENNA MY SATELITE ANTENNA IS DEAD CENTER JUST BEHIND THE ROOF ANTENNA
boydstir
IF YOU WANT A PICTURE JUST LET ME KNOW
| Tags |
| antena, gps, repair |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| in dash nav system | uncleyaris | Cosmetic Modifications (Exterior/Interior) | 1 | 07-03-2009 10:16 PM |
| Legal Windshield Tint Ideas | Pitt Yaris | Cosmetic Modifications (Exterior/Interior) | 21 | 06-05-2009 12:57 PM |
