Old 07-10-2009, 03:21 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Request for help: diagramming a relay
In order to work around the issues I'm having with my Pioneer AVH-P3100DVD head unit always prompting the OK screen when the unit is restarted while viewing a DIVX file, and often failing to restart the audio at that time, I am pondering using a relay to keep it powered as long as the 12V accessory bus is powered up but having it draw power directly from the battery rather than the accessory bus.
I think I can do this with a standard 5-pin SPDT automotive relay but would like confirmation. I would wire it as such:
30: fusable link to radio's ACC line
85: ground
86: fusable link to 12V battery
87: not used
87a: fusable link to 12V accessory bus
Would that work?
And would it be enough, or would I need to yank the "ACC Cut Relay" as well?
- Brian
Share the Road
Old 07-10-2009, 03:30 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
if your installer wired your radio properly you shouldn't have this problem. there is a 12V constant already in the wiring harness AT the radio. this is what keeps the radio memory intact.
Old 07-10-2009, 03:38 PM   #3
BailOut
BailOut's Avatar
This is not an issue with the radio's memory but with it being power cycled when a key start occurs. This is its expected behavior as the whole accessory bus is cut out during a key start.
I am attempting to bypass that by drawing power directly from the battery but only when the 12V accessory bus is powered (so that it will turn off when I turn the key to the off position).
I installed it myself, btw, and it works as intended. Now I'm trying to take it beyond what was intended.
- Brian
Share the Road
Old 07-10-2009, 03:40 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
the constant wire at the radio is just that. constant.
you don't need to do this at the battery.
Old 07-10-2009, 04:10 PM   #5
BailOut
BailOut's Avatar
Good point, but that only changes one connection point on the relay. A way for it to cut out when the accessory bus is not in use is still needed.
- Brian
Share the Road
Old 07-10-2009, 04:11 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
diode between ACC bus and radio feed.. wait nevermind haha...
why not simply shut off the stereo every time you're done using it? or does it still lose its position if you do this?
Old 07-10-2009, 04:35 PM   #7
BailOut
BailOut's Avatar
I can see myself forgetting to turn it off someday and returning to a dead battery. Hence my desire for it to cycle off when the ACC buss is off.
- Brian
Share the Road
Old 07-10-2009, 04:49 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
no, i mean shut it off now, don't change the wiring at all. if it's "off" it should retain the settings thru the constant wire, as opposed to resetting while it's in ON and loses ACC power, right?
Old 07-10-2009, 05:07 PM   #9
BailOut
BailOut's Avatar
Tamago,
I appreciate you trying to help but you're quite far off the mark and don't seem to understand what I'm trying to do here. I asked for help with diagramming a relay so let's stick to that, please.
- Brian
Share the Road
Old 07-10-2009, 06:40 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
Tamago,
BailOut, i understand fully what you're trying to do, and i don't appreciate it in the least. I'll hunker down and be helpful now.
Old 07-10-2009, 06:49 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
30: common to battery 12V
87: common to "stereo power wire"
85: common to "starter solenoid 12V"
86: common to GROUND.
87a: not used
so, only when the starter solenoid is engaged, the relay is in operation. because you're using 87 (NO contact) you won't be powering anything when the key is turned off. and because you've hooked 30 to "constant" your ACC circuit will be backfed power directly from the battery during the "start" cycle. since the ACC circuit does not power high-draw items such as the windows or AC or fan or defrosters, you should not have an issue with battery draw during the "start" cycle.
sound good?
also, this can all be done right at the radio (no need to run a feed from the battery itself)
Old 07-10-2009, 07:28 PM   #12
BailOut
BailOut's Avatar
87a: not used
sound good?
Ahh - now we're getting somewhere. Thanks! That sounds like a solid idea.
Though it can all be done "at the radio" where would I tap into the "starter solenoid 12V" line? From the engine compartment, I presume?
- Brian
Share the Road
Old 07-10-2009, 07:31 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
i don't know the actual yaris wiring diagram so i won't say what i think is the obvious answer (at the ignition itself). for all i know the yaris uses sinking switches instead of sourcing to send the "start" signal.
Old 07-11-2009, 12:29 AM   #14
How about just eliminating the ACC cut relay and jumping the output contact terminals? The service manual says that its purpose is just to keep the clock and meter from flickering during cranking.
You could use a jumper wire with male spade terminals. Jump 3 to 4.
Old 07-11-2009, 01:49 AM   #15
BailOut
BailOut's Avatar
That sounded like a great and simple idea but it did not work. I jumped 3 to 4 to no effect. The interesting thing is that the clock works just fine (no flickering) with or without the ACC cut relay or 3-4 jumper in place.
Thanks for trying, though. Tomorrow afternoon I'll try wiring in a relay.
- Brian
Share the Road
Old 07-11-2009, 10:04 PM   #16
BailOut
BailOut's Avatar
Tamago,
Another great but ineffective idea. The problem is that the ACC bus is cut out by the ignition key's rotation long before the starter solenoid is active. You can see this by turning your key to the on position and waiting for your stereo to power up, then slowly cranking the key towards the Start position.
My own wiring idea in the first post doesn't work, either. What I'm going to need to do is hook the stereo's power up to a line that maintains power during a start. I know the brake lights and ECU retain power during a start, but the brake lights are powered at all times and I am wary of tapping into the ECU's power supply.
Does anyone have other ideas, please?
- Brian
Share the Road
Old 07-11-2009, 10:56 PM   #17
OK. I see that now. When the keyswitch moves from on to start the ACC feed is switched to the IG1 feed.
How about jumping ACC (white in pin 2) to IG1 (green in pin 1) at the keyswitch? That way regardless of the keyswitch position ACC will be energized.
Old 07-12-2009, 03:19 AM   #18
BailOut
BailOut's Avatar
Thanks for another great idea, CTScott, but jumping pin 1 to pin 2 on the key switch did nothing. No change at all. I also tried removing the ACC cut relay with the jump in place, which doesn't even allow the stereo to turn on at all. I also tried jumping pins 3 and 4 on the ACC cut relay while leaving the key switch jump in place, which allows the stereo to turn on but still allows it to be killed when engaging the starter.
This is turning out to be one bugger of a problem!
- Brian
Share the Road
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 04:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 07:01 PM
DRL Relay andru47 Willing to Buy by private party 1 01-06-2009 06:47 PM
F/S Micro Relay for foglights. 1NZYaris1 Items for Sale by private party 7 12-29-2008 10:32 AM
