Old 07-29-2009, 03:25 PM   #1
Vince87
Drives: 2007 2DR Yaris
My little baby wont start !
This morning when I was leaving for work my little yaris (2007, 33000 km) didnt start (totally dead, no accessories or anything). I jump started it with my GF's car and went to work (30 min of driving). When I parked it, I tried to start it again and it did the same thing... Now I'm gonna have to take it to Toyota for a checkup but the thing is I just installed the DIY cruise control and I also have a subwoofer hooked on the battery... Do you guys think I shoud take everything off before going to Toyota or I can leave it as it is ??? Thanks guys
Vince87 is offline   Reply With Quote
Old 07-29-2009, 03:54 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
If the car runs fine once jump started, my guest is a dead battery. or something is draining the battery.
check the battery with a volt meter.
Old 07-29-2009, 04:04 PM   #3
markitect
Drives: Yaris
Depending on how dead the battery was, it may never hold charge again.
I would also be suspicious though if your subwoofer is hooked up in such a way that it is always draining power. I would check the battery and if it is ok take out the subwoofer and see if it holds charge then.
markitect is offline   Reply With Quote
Old 07-29-2009, 04:11 PM   #4
Vince87
Thanks for your help guys ! CAA just came to charge my battery and saw that I only had a bad contact (the ground wire was loose, it's my fault I disconnected the battery when I installed the sub and didnt tight it as much as I should)... My car runs fine now !
Still do you think that Toyota would have something to say againt my Cruise Control installation if I do have to take it to the dealer for a repair under warrenty ?
Old 07-29-2009, 05:34 PM   #5
PatrickJohnson
Drives: 2008 Yaris LB
not unless your warranty issue is ECM related. And even then, they have to prove your mod caused the fault. Burden of proof for warranty refusal is on the dealer.
PatrickJohnson is offline   Reply With Quote
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 12:39 PM
Remote Start Questions revnull In Car Entertainment + Electronics (audio / video / alarm) 8 02-28-2009 07:05 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 06:06 AM
Car wouldn't start up thatboyjer DIY / Maintenance / Service 8 07-25-2007 08:17 PM
Tip Start machine1 General Yaris / Vitz Discussion 12 02-19-2007 04:08 AM
