toyota
would 16x8 with +25 offset fit on the rear?
would 16x8 with +25 offset fit on the rear without rubbing when car is full?
what tire?
i'm wagering NO, not without some camber added or some fenders pulled.
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
NO!!
I have 16x7 +42 offset all around, 15mm spacer on rear, stock camber on rear, front should be like 0.5 more than stock. I already rub the front in full turn ![]() I rub the rear in some small bump, even with no passenger!! I've try e passenger with me at the same time, super rub even on local... I think you have to run a large camber..if you want to run 16x8.... but still need to see how low you are
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
toyota
thanks...so 16x7 +40 on the rear its safe to put 10mm spacers to get zero rub even when full but i may be runnign 195 on the tires. assuming u got 205s
yes, an effective +30 and a 195 tire you'll be fine with a X7 width
I'll rub the front a little bit, when I push it hard in some corner, but you should be fine if you run some 195 tires
toyota
im thinking of staggered set up front 16x7 +40 offset and then rear 16x8 +25 offset car is in trd spring but may switch to df210 later on. plus camping month the car get full so i dont want rubbing on the fenders..
#8 | |
BTW - this is your 3rd 'rub' thread isn't it?
#9 | |
![]() he just don't want to get rub
#10 | |
toyota
but the way the rubbing issue is on the side of the fender..so trd or df210 should not make a difference if u got the right offset and tire size.. 2 person on the back on the trds tucks the tire on the fender..just like that. Last edited by marcus; 06-23-2009 at 06:31 PM. |
Apexing Egg!!
i have 15x7 +25, no rub. i could actuall use a spacer in the rear (i have some camber too)
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
here is some pic of mine, 16x7 +42, 15mm spacer in the rear
if you run 16x8 +25...you should be (0.5"+2mm) more flush than mine at the rear..... i think you should be rub when your car get full..... (with the stock camber)
i'm not lowered by spring, so may be yours are little bit higher than mine, but softer....
toyota
i find trd / eibach pro kit i believe really soft..which maybe a good thing most of the time.
![]() ![]() Drives: 07 yaris hatch Join Date: Jul 2009
I'm interested as I'm putting 16x8 on rear of my lb. Pretty sure I'm gonna roll the fenders. How much should it cost?
| 16x7 +38mm front, 16x8 +0 rear WILL IT FIT? | wildmongoose26 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 02-23-2014 11:04 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
