![]() ![]() Drives: Yaris D4-D Join Date: Aug 2006
[Detail] Corolla AE86
The car in question is a Corolla AE86 of a friend mine of the year of 1987.
The painting is of origin, this Corolla never gave problems or it was not Toyota. This detail was distribuido of the following form: Late and night of 2ª fair, late of 3ª and 4ª fair, complete day of 5ª fair, and today 6ª fair for the photographic session… leaving the paleio of part is the photos of the one here Well before ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The process for the laudering with Sonax and the beautiful of the followed glove of the decontamination of the painting was initiated ![]() Already all descontaminado, initiated the isolation to pass to burnishing ![]() They had started entao for “attacking” with sponge of burnishing and IP that if disclosed insufficient. In a section to the side we test a solution a little more abrasive, and still without passing to the PG, we test the IP with yellow sponge of cut that also if disclosed not to be capable to give account of the message. There they had had that to opt to the yellow one + PG that was used to pass in “the still virgin” sections. In the sections that already had tested it was transferred plus one the two times white + IP the same stops for the painting all in state. Here my friend to give to it with yellow and the IP. To notice that in the first day we appeal to “normal” lampada to see swirls therefore our searchlights of halogeno with the tumbles in the bagageira they were with the casting lampada one. In the following day already it counted them to me with lampada of halogeneo. ![]() to remove the excesses of polish… ![]() E the first results to be appeared ![]() The first results had been so positive that we do not resist to give FF in that bit soon… E the results one more time are at sight. The part that reflecte the PC already had been polishing with FF Already without the ribbon… it is noticed difference ![]() Here already the cowling practically soon ![]() In the remaining portion of the car, they had been adaptandom burnishing to the state of superficie. The laterals had been only polishing with white and seen IP if not to justify the use of the PG. In some very especificos points happened again burnishing with IP, without appealing to the PG. ![]() ![]() Yes, that is the white sponge…. ![]() Interiors we here go ![]() For the interiors they had disassembled the banks of the front to clean alcatifa better and the proprios banks. The interior was all clean with APC and the brush triple duty of the Meguiars that is to hiper useful! Alcatifa was inhaled, clean with APC and a brush and inhaled all again. The estofos had been inhaled, clean with APC, inhaled again. Upholstery had still used 1z Carpet and foam for the banks, had brushed well and inhaled the banks one more time. The skin of the banks after clean with APC was conditional with Poorboys Leather Stuff with shining results (that one smells the skin….) ![]() ![]() ![]() Before versus Later ![]() “Later” he seems spotted but it is only moistness of the foam that not yet had dried in the totality. Before ![]() Later ![]() Here the carpet covered of foam ![]() E one more time… Before versus Later ![]() E here a photo of the interior already practically finished: ![]() The plastics had been all the treated with 1z Tiefen and conditional rubbers with Gummy Pfleger. ![]() ![]() ![]() They had passed then to the diggings of wheel and the engine. What it was made in the engine not if can consider a detail, therefore we clean with Engine to degreaser of a short while superficial form and only treat some plastics and rubber. ![]() Here the digging already washed with engine to degreaser. In the deep o tar it has that esquesita color and he is really clean… the aspect is that he is not optimum the plastics of the digging had been dealt with balsam. The part of inside of the clean cowling already. ![]() The engine before: ![]() Here during the cleanness ![]() Here only some plastics were conditional… the rubbers not yet had seen gummy… ![]() Unhappyly we do not have photos of the final result therefore we estavamos tao compenetrados in the detail in itself that we take off few photos and the few that had been taken off was for the owner of the car. Coming back to the exterior of the car… The plasticos had been polishing with Meguiars PlasticX and the polishing glasses with 1z Glass polish. ![]() E here the treated lighthouse after ![]() The final inspection started then ![]() E followed the finishing with black color + FF ![]() Car pra is there… To make finishes it laudering, of this time with Raindance ![]() You have supper them that there they were had not been treated therefore, as they must already have repaired you have supper them had been changed by news that they had been only clean with APC where necessary and stamped with PWS. The tire substitute also was white of treatment… Laudering with 1z Wheel Cleaner, stamped with PWS and New Tire Look in the tires Continuing ![]() Lackfinish... ![]() ![]() To dry… the car until already it smiles ![]() It was finished applying grojet with a wet applicator MF and the Nattys Blue… ![]() Consequences? Some details had been finished only…. ![]() Clean escape and antenna with 1z Crome and metal polish…. Clean with windscreen to clear and stamped glasses with grojet. Plastics with Balsam and rubber with gummy. Tires with 3x New take off look. E garage with it… In the following day one “End was followed inspection” with the QD of meguiars and was followed it photographic session of the custom. ![]() ![]() ![]() ![]() ![]() ![]() ![]() E as prettier than a machine of these detailed only exactly a machine of these detailed… to walk ![]() ![]()
![]() ![]() ![]() ![]() ![]() Drives: icebox Join Date: Apr 2006
Very nice,.. wanna come to Canada and detail mine?
Certainly it has people that they make details in Canada. ;)
Wow.. impressive. Nice shiny ride
Five-Star General
beautiful car, absolutely beautiful, sometimes its an art to clean a car
![]() JWU '09 Baking and Pastry
Sir, your services are requested in New Jersey, USA to detail the crap outta every vehical I own!!!!!!
Major props buddy, it looks AWESOME!!
Yeah, this guy is extremely thorough. You could make some serious money in the States my man.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jul 2006
Did I just see what I thought I saw??? That's the devil's work!!
That side by side comparison, the freakin paint looked new! Imagine what a "new" new paint job would look like??? We gotta chip in, bring these guys over, on tour, if you will!!!! Props given to the max!!!!!
Each detail in Portugal costs 150€/200€ here.
It will be that he is expensive? How much it is that it costs in your land? |
Yeah we have detailers in Canada.. just not ones that do work like that... A++++++++ job!
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
Pictures dead...
![]() ![]() Drives: 07' Yaris HB | Blazin' Blue Join Date: Sep 2006
Come perform your sweet art on my Blazing Blue LB... Amazing, absolutly Amazing.
Small Car Lover
Wow! you guys did a great job! I like the pictures of the car where the trees are. Major props for the work.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#14 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Great job
You should look into using Zaino products on your finished results for an unbelieveable finish.
The early bird gets the worm, but the second mouse gets the cheese. |
#15 |
![]() ![]() Drives: 07 Yaris HB Meteorite Metallic Join Date: Sep 2006
Wow.. you guys are amazing....
#16 |
![]() ![]() ![]() Drives: 05 YRS Silver Lining Metallic Join Date: Jan 2006
yeah, top job! black is always a bitch to maintain...
#17 |
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
:( I miss my ae86
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
#18 |
Yarii Hunter
Drives: 2007 Yaris Liftback and S13's Join Date: May 2006
Wow! This is EXACTLY what I needed to see to get started detailing my trio of S13 240SX's ! Thank you for the MOTIVATION!!! I am simply amazed by your PERFECTION !! Do you speak Portugese or Spanish? Your english IS MUCH beter than my Spanish (or French for that matter)
Thanks for all the help over the years, YarisWorld!!!
| [Detail] [as to make ] Auto Laudering | Sérgio Barros | Wash, Wax, Detailing, Exterior Repairs | 4 | 08-22-2006 03:56 AM |
