Old 09-14-2009, 11:02 AM   #1
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
afc and egt?
One of the old gatway dsm guys was running an apexi afc with an egt gauge and leaning it out as much as he could while making sure he didn't melt his turbo off...anywho, moral of the story is he was hitting around 60-70mpg highway in his 2g eclipse. Was wondering if anyone had tried this out here looking at these mods from a gas mileage perspective as opposed to a performance perspective?
I'm thinking if the same thing could be pulled off here it might be possible to hit 80-100mpg doing about 55mph on the highway...
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
Old 09-14-2009, 12:40 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
hmmm... very interesting... It'd be very fun to try... anybody have a few thousand to donate to me so I can experiment with this.
Old 09-14-2009, 01:31 PM   #3
Y@R15
Dude wheres my car?
Drives: 98 honda VTi
sounds good but what if the speed limit is 70? dont you get pulled for impeding traffic?
Y@R15 is offline   Reply With Quote
Old 09-14-2009, 01:48 PM   #4
o89canucks
Mechanic from hell
o89canucks's Avatar
few thousand??? Wow, who are you buying parts from?
Apexi safc neo - approx 350$
autometer ultralite egt gauge with probe - approx 130$
self installed you would be talking around a 500$ investment total.
and the maximum speed limit is 70mph, minimum is usually 45mph.
Old 09-14-2009, 06:28 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I don't have a turbo... I thought you were talking about doing this in conjunction with a turbo?
Old 09-14-2009, 06:38 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
there has been much debate about that topic right there buddy, you don't even know LOL...
as for the topic of this thread, it'd be a nice twist to see someone get a turbo for the purpose of getting higher mpg vs. acceleration and mph lol...
Old 09-14-2009, 08:06 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
how do you plan on leaning out the fuel on a stock yaris?
Old 09-15-2009, 03:18 PM   #8
o89canucks
Mechanic from hell
o89canucks's Avatar
did you miss the part about the air-fuel controller?
Old 09-14-2009, 08:26 PM   #9
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
don't do it
Originally Posted by xnamerxx
you nailed it sir.
Old 09-14-2009, 08:28 PM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
the reason the 2G eclipse guy made those numbers was because of the turbo.. you'll never achieve it on a yaris
you nailed it sir.
Old 09-15-2009, 03:17 PM   #11
o89canucks
Mechanic from hell
o89canucks's Avatar
I don't see a difference on leaning out a turbo vs. na car, leaning is leaning wether you have a turbo or not.
Old 09-15-2009, 03:24 PM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
the difference is that the DSM guy is probably leaning to 14:1. turbos make engines more efficient, volumetrically and thermally (at low boost)
stoich is 14.7:1. that's what the yaris ECU is going to try to achieve in closed loop. leaning the engine out further will simply overheat the exhaust manifold, as well as your pistons, valves, everything.
so you'll get better fuel mileage at the cost of engine longevity, which does more harm to the environment than leaving well enough alone.
you nailed it sir.
Old 09-15-2009, 03:53 PM   #13
o89canucks
Mechanic from hell
o89canucks's Avatar
Longetivity, yes, if you exceed safe temp ranges...which is what the egt gauge is for. Cast iron exhaust manifolds are made to withstand temperatures up to 1600F before doing major damage, I still wouldn't recommend running that hot for any extended period of time though. You still may get a decent gain by running egt temps 2-300 degrees over stock levels.
Old 09-15-2009, 03:29 PM   #14
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
how much adjustment can the AFC do on the yaris?
2%, 5%, 10%, 25% adjustment?
This is an expensive test to save $40 a tank, but I'd be interested to see it perform.
Airplane pilots do this constantly while at cruise to get optimum results.
Penguin Garage is offline   Reply With Quote
Old 09-15-2009, 03:38 PM   #15
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by Penguin Garage View Post
h
airplane pilots have sub-zero air to induce and cool their intercoolers ;)
you nailed it sir.
Old 09-15-2009, 03:43 PM   #16
Penguin Garage
Drives: Yaris
and not alot of traffic, oh and auto pilot.
kind of a bad example really. haha.
Old 09-15-2009, 04:59 PM   #17
Penguin Garage
Drives: Yaris
anyone care to comment?
Old 09-15-2009, 05:04 PM   #18
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
the afc increments change depending on what rpm it is. I had an AFC2 on my Conquest and it was a great tool. There is more adjustments you can make. Although I am not sure how the AFC Neo works and what you are capable of doing with OBD2 and up.
Doesn't the AEM FIC allow you to adjust a few different parameters of the motor?
