Old 08-10-2009, 09:36 PM   #1
Yanick
Drives: Yaris 2007 sedan
adding AUX input, Can this be done?
Hi everybody, I have the sedan 2007 with the stock radio
is there an easy way to install an aux input on this radio?
Thank you!
Yanick is offline   Reply With Quote
Old 08-10-2009, 09:53 PM   #2
texkid
The one with cheese on it
Drives: '10 Corolla S
Hmmm...maybe.
Take out the radio and check the back for AUX connection.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 08-10-2009, 11:30 PM   #3
Yes, you need the Aux Jack (part number: 86190-53010). Check and see if the cable is there (from the back of the radio to the Aux jack location, below the AC knobs).
Old 08-11-2009, 06:25 AM   #4
Yanick
Thanks a lot, i'm gonna check this tonight
Old 08-11-2009, 05:49 PM   #5
Yanick
not working
I found the plug, I also found another thread about this so after reading all the posts I decided to test it, I made a test cable and connected it to the plug.
...nothing...
pin 1 and 2, left and right audio
pin 3 and 4, audio ground(jumped the 2 together)
have I missed something?
Thanks for the help!
Old 08-11-2009, 06:02 PM   #6
PatrickJohnson
Drives: 2008 Yaris LB
i don't think both of those are ground. factory aux is only enabled when an input device is detected, so i'm guessing one is a signal line of some sort, more likely tied to the left audio line.
PatrickJohnson is offline   Reply With Quote
Old 08-11-2009, 07:37 PM   #7
Yanick
well I tried connecting only left and right audio + audio ground, and leaving pin 4 unplugged, won't work
I also tried tying pin 4 to left audio, won't work either
Old 08-11-2009, 09:05 PM   #8
In order to activate the Aux input, AUXI (on the radio end) or AUXO (on the aux port end) needs to be connected to AGND. Once they are connected you can switch to the aux input, even without a device attached. Connecting those two pins together is a quick and dirty way of verifying that a HU can take Aux input.
Old 08-11-2009, 09:20 PM   #9
Yanick
Thank you very much for your help, but it seems my HU won't take the aux input
I jumped AGND and AUX0 and the radio won't enter aux mode
guess I will have to buy an aftermarket radio but I have to find one wich has a rear aux input, I don't want a wire up front, I feed my music via bluetooth a2dp via my ego talk handsfree
anyway, thank for the help, really appreciated!
Old 08-11-2009, 10:03 PM   #10
Try one more thing - connecting AUXO to chassis ground.
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
aux input for Canada RS 6 disk changer jerry022 In Car Entertainment + Electronics (audio / video / alarm) 4 06-02-2009 04:30 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
aux input... djfuji In Car Entertainment + Electronics (audio / video / alarm) 3 01-23-2007 09:25 PM
