Old 09-24-2012, 07:39 PM   #1
Aleil
Drives: Toyota Echo 2000
Need Help with 2NZ ECU pinout
Dears , i need help with an 2NZ ECU Pinout , the story is that i did an engine swap for my Echo/Yaris ( model 2000 ) from the 1SZ 1.0 to 2NZ 1.3 , the problem is when i got the new engine i found that the ECU sockets is different from my old one , the first Pic is for the old ECU and second Pic is for the new one ( the pic is not mine i found it random from the internet while searching but it's the same like mine ) , the problem that i can't match the old wiring system coming out of the dashboard to fit the new ECU , also some problems like that engine Tep. lamp is not getting the right signal as My car is with the digital Dashboard so the Temp. is a lamp not an amber one , the big problem that when i try to connect the Diagnose device to do the diagnostic test the device is not responding which mean that the socket is not connected rightly , and for sure the Check engine lamb is not responding too
so i am looking for this ECU pinout as all the Pinouts that i found for 2NZ look like the old socket ECU not this new one , I got the engine from the dealer as it's for Toyota echo/yaris 1.3
can any one help me out with this !
Aleil is offline   Reply With Quote
Old 09-24-2012, 09:33 PM   #2
For the 2nd generation Yaris, the 1NZ and 2NZ have the same pinouts, but for the 1st gen it appears that they are different, since the ones I have for the 1NZ don't match the connectors on your 2NZ ECM.
I would recommend subscribing to the Toyota Europe technical site to download the ones you need:
http://www.toyota-tech.eu/SearchPubl...px?PUBTYPE=EWD
Old 09-25-2012, 11:20 PM   #3
Aleil
Thanks a lot , i'll try this solution hope to find something :)
Old 12-28-2020, 10:40 AM   #4
benjie30
Drives: vios
i also need this ecu pinout pls help
benjie30 is offline   Reply With Quote
Ecu Pinout? karlblanchard Performance Modifications 6 05-20-2014 06:25 PM
ecu pinout and plugs fugazzye Performance Modifications 0 02-24-2012 12:47 PM
ecu pinout 2006 yaris d4d faiscamix DIY / Maintenance / Service 3 12-16-2010 02:58 PM
Yaris 2006 1KR-FE ECU pinout? Yules Performance Modifications 4 06-23-2010 09:12 AM
ECU pinout ChinoCharles Performance Modifications 78 04-08-2007 07:10 PM
