Old 10-26-2009, 02:40 AM   #1
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Yari Boosted, Enge lite...
Hey Guys,
I just got my Yari boosted, and man, it sounds great, feels great, i am boosting about 0.4bar, but as soon as I start driving a bit, the Engine light goes on, the motor is 1krfe, and I need help very urgently!!!!
How is the best way to get rid of the limp mode! Over here I can get the car chipped no problem but I need help first and understand what it is doing and how I can get the problem sorted fast!!!
PLEASE HELP!!
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 10-26-2009, 03:33 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
get a Scanguage to read the code , then solve the problem
Old 10-26-2009, 12:24 PM   #3
You need to know boost and air/fuel when that happens. Lean or rich will determine two different fixes. Got gauges?
Parts list, please. Can't help much without knowing what you did to your car.
Old 10-26-2009, 10:50 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
pictures too, lol
Old 10-27-2009, 04:52 PM   #5
where's the OP?
Old 10-28-2009, 04:03 AM   #6
N3misiS
N3misiS's Avatar
Hi Guys, Got the problem it is running Lean, and I am adding a micro Fueler plus extra injector, I need to know where the pickup wire is for the Rev Counter and ASAP because the car has eerything in it... I just need to know where to hook up the wire and done!!!
It is the 1KRFE motor, I will send you guys the Dyno charts and pics asap.
Old 10-28-2009, 11:14 AM   #7
why not just larger injectors all around? Isn't that easier than managing an extra injector?
Old 10-28-2009, 11:20 AM   #8
x2
Old 10-28-2009, 11:29 AM   #9
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
nope.
Originally Posted by xnamerxx
you nailed it sir.
Old 10-30-2009, 02:16 AM   #10
N3misiS
N3misiS's Avatar
Hi Guys,
I now need some real help...
First, evrything is working, so the now the engine lite goes on, we try and add more feul because the problem is there, my meter shows it is running Lean (16.5) and no matter what you do it stays there, so he only thing in the way could be my exhaust is not big enough (48mm) or the map sensor\air flow meter is giving me stick because it is picking up boost.
if anyone knows where the am senor is please tel me, it is a 1krfe motor.
Please it is urgent, i really do not whant to break it or burn holes through my pistons.....
Thanks guys!!!
Old 11-02-2009, 05:51 AM   #11
N3misiS
N3misiS's Avatar
Hey guys,
I think I found the problem with adding a turbo...
this can aply to 1300cc and 1000cc after studing the wonderful diagrans I got here.
I added the turbo, working, sounding like an EVO... then came the feuling so I added a extra injector and a micro fueler using a hob switch to pick up boost and start pumping fuel.
and still not getting it...
this weekend I inspected the car, removed the throtle body and found that there is a Mass Airflow and map sensor in one, the same as you get on Honda and VW, and that is the problem with most of these things...
today it is getting tuned and A\F checked and so on...
as soon as I ca I will ad pics and vids for you guys.
Everyone has been a great help, and also one more note....
Building your on boost\intake and exhaust is a hell of lot of work especially from scratch.
Now oe thing I need is some pointers to keep in mind what not to do, my car wil get services every 7000Km's or so mostly oil as for the heat and every 11-14000Km for spark plugs belts etc...
Thanks Guys.
Old 11-02-2009, 04:21 PM   #12
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Originally Posted by N3misiS View Post
Hey guys,
Thanks Guys.
Wait, so you think the problem is the MAF/MAP sensor? Umm no. The car is doing what its supposed to do.
When the stock ECU sees boost, it freaks out. It will throw codes and go into limp mode immediately. Since there's no real engine management available for the Yaris, you have to trick the ECU with a piggyback or something that will clamp the map/maf voltage then add fuel/timing appropriately in boost. Adding one extra injector for fuel managment is probably the craziest thing I've ever seen, and trust me I've seen a lot.
Do you know what fuel pressure you're running? The yaris is a returnless system which probably operates on a static pressure no matter what, not the best idea in FI
What about ignition? Fuel is 1 part of tuning a car, timing is just as important? Need to retard timing in boost.
Glad to hear it sounds like an EVO though. Good job on that rofl
The Spectacle is offline   Reply With Quote
Old 11-02-2009, 04:28 PM   #13
Question, why are you in such an URGENT hurry? Several people are trying to help you. Slow down, let us know what you have and lets take it from there =)
Old 11-03-2009, 01:43 AM   #14
N3misiS
N3misiS's Avatar
Thumbs up
Hey Guys,
Thanks!
But its already done and working....
Tuned to perfection....
Extra injector worked, but one more thing....
the problem is the MAP\MaF sensor, we did something to it...
and you know, there are no error codes, no limp mode,
no nothing, my A\F mix is 11.7 under boost, no detonaion...
I will take it to a Dyno and then show you what I got, plus pix...
I need to make it pretty now, he problems is sorted and that is all I needed for now...
And everything thanks to NC Speed Conversions SA, and Yaris world!!!
Old 11-20-2009, 08:22 AM   #15
Yaris - GP
Drives: 2007 Yaris Sedan
Nice to see a fellow South African on here.
Are you at the coast or up on the reef? That would put the power figures in perspective.
Looking forward to the dyno results.
Yaris - GP is offline   Reply With Quote
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 06:49 AM
New photos of my Yari with my new suspension - coilovers (track) Trish Photo-Video-Media Gallery 35 05-25-2009 01:56 AM
