Old 10-30-2008, 06:07 AM   #1
Midon
Mod Freak
Drives: 88 MR2 GT
I ahve a question about door locks
I don't have anything power on my 08 LB I want to change the doors to electric locks but I don't want a switch I just want a key fob unlock the doors. Now since I don't have electric door locks how do I do this If I buy a after market kit will it come with everything I need to make the door locks electric and to work with a key fob. Also what is a good brand, I don't want to spend a lot of cash to do this.
Midon is offline   Reply With Quote
Old 10-30-2008, 06:26 AM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
all keyless entry systems you buy are for powered door lock no keyless entry comes with the actuators as they are designed for cars with powered door locks. what you would need to get is the keyless entry and 2 door lock actuators to add the powered lock portion. and wont add any switchs youll get two key fobs in my opinion
door lock actuators need two of them
viper 211hv
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 06:44 AM   #3
Midon
Mod Freak
Drives: 88 MR2 GT
K thanks were do I get all this at. And how do u mount the actuators or should I rob a junked yaris at the junk yard if I find one hehehe
Old 10-30-2008, 06:52 AM   #4
battleversiontc
well the actuators they sell them at radioshack.com only online tho but there like $10ea and come with the instructions the keyless idk if directed electronics would just sell it but its listed on there site for 119.99 but if the do sell it then it cheap and easy and viper products are like the best out there. to do the door lock actuators try look on www.the12volt.com they normally have alot of helpful stuff like wire diagrams for the car and how tos its actually pretty cake to install door locks cant mess it up if you follow the instructions i can explain how to but it wouldnt make sense unless i took pictures of the process unfortunetly tho dont have any appoinments i can do that sorry
Old 10-30-2008, 06:56 AM   #5
Midon
Mod Freak
Drives: 88 MR2 GT
sweet thanks bro
Old 10-30-2008, 06:59 AM   #6
battleversiontc
heres a link to kinda show how its done or what it should look like minus the cable i think the yaris uses a rod instead of a cablehttp://images.google.com/imgres?imgurl=http://www.elantraxd.com/DIY/actuator1.jpg&imgrefurl=http://www.elantraxd.com/DIY/actuator.php&h=600&w=800&sz=118&hl=en&start=24&um= 1&usg=__tlgSfK_z8S4DRTlQg7AiSWpoPgk=&tbnid=c5EfZ81 NsiASmM:&tbnh=107&tbnw=143&prev=/images%3Fq%3Dhow%2Bto%2Binstall%2Bdoor%2Block%2Bac tuators%26start%3D20%26ndsp%3D20%26um%3D1%26hl%3De n%26sa%3DN
not a problem good luck when you do it maybe you can do a diy while you at it
Old 10-30-2008, 08:32 AM   #7
viper 211hv
Make sure you get three - You really want the hatch to unlock as well. If you can find a set of actuators from a junk yard car life would be easier. The aftermarket ones work fine, but sometimes figuring out a good way to mount them can be tricky.
Old 10-30-2008, 09:52 AM   #8
Midon
Mod Freak
Drives: 88 MR2 GT
was there a power lock for the LB in 08
Old 10-30-2008, 10:09 AM   #9
Yes.
The Part Numbers for the OEM Toyota parts are:
Lock Assembly, Front Door W/Motor, RH: 69030-52470
Lock Assembly, Front Door W/Motor, LH: 69040-47060
These replace the standard lock assembly
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
This is an addition to the rear lock assembly
Old 10-30-2008, 10:13 AM   #10
Midon
Mod Freak
Drives: 88 MR2 GT
sweet thanks bro I might just get some new ones
Old 10-30-2008, 12:32 PM   #11
b_hickman11
Drives: 08 Sedan
http://www.a1electric.com/Merchant2/...ode=W01C-RF104
This is the kit you want to buy. It has everything you need and doesn't have extra stuff you don't need. I installed this kit(the 4-door kit) in my 07 Sedan. It was very easy to install and it works great. You could probably install the 2-door kit in 2-3 hours.
Old 10-30-2008, 01:57 PM   #12
Midon
Mod Freak
Drives: 88 MR2 GT
how easy did the actuators bot up and did u getthe cable or rod kit?
Old 10-30-2008, 05:10 PM   #13
Pitt Yaris
Drives: Flint Mica Sedan
how much would it cost to simply get automatic door locks?
Old 10-30-2008, 05:53 PM   #14
seehuge
Drives: BMW 325i
yaris needs the cable kit
seehuge is offline   Reply With Quote
Old 10-30-2008, 11:34 PM   #15
b_hickman11
Drives: 08 Sedan
The link I posted was for the cable system which is the one you will need.
Old 10-31-2008, 01:05 AM   #16
battleversiontc
damn totally forgot about the rear lock my bad
Old 12-15-2008, 07:34 PM   #17
Pitt Yaris
i'm guessing you had power locks, but no keyless entry?
Old 12-15-2008, 09:17 PM   #18
b_hickman11
Drives: 08 Sedan
No, thats why that link is for a power lock kit with keyless entry. I posted the 2 door version because he has the LB. And I said I bought the 4 dr version.
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
question bout aux port SurfBabe900 General Yaris / Vitz Discussion 1 05-28-2007 02:18 PM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
