Old 09-02-2009, 10:45 PM   #1
bronsin
bronsin's Avatar
Changing Front Brake Pads
My wifes 2005 Camry is going to need front pads soon. Ive changed them myself on other cars and wonder if this car is similiar? I seem to remember 2 14 mm bolts holding the calipers on? Push the piston back into the caliper with a large C clamp? Thanks for any help!
Old 09-03-2009, 12:09 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
sorry, don't know the answer for you; but ill bump this up for ya!
Old 09-03-2009, 10:43 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Quite similar.
Old 09-03-2009, 10:51 AM   #4
S/B the same or very similar. Hell, I recently did a friend's Santa Fe, and it was nearly identical.
Old 09-03-2009, 11:08 AM   #5
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes - brake tech - even with ABS has not changed all that much in forever - your method will work fine, and the bolt size is 14mm as you recall
pariahdecss is offline   Reply With Quote
Old 09-03-2009, 02:31 PM   #6
bronsin
bronsin's Avatar
Thanks guys. I ask because I have neck and back issues. This will be a challange and I dont want any suprises!
Old 09-03-2009, 03:16 PM   #7
Yaris Hilton
Smile
Changing pads is pretty straightforward. If you have neck and back problems, getting the car jacked up and the wheels off and back on may be your biggest challenge.
I just looked and found a bunch of videos on changing brake pads and rotors on YouTube, if you need them. Rotors should be OK if they just have wear that looks like the grooves on an old record. If they have deeper grooves that feel ridgy to a fingertip or will catch your nail, they need to be resurfaced or replaced. Nowadays you can get new Chinese rotors for what it costs to get your old ones turned.
Old 09-03-2009, 04:32 PM   #8
^ true. R1 Concepts OEM rotors $73.99/pair
Old 09-03-2009, 07:45 PM   #9
bronsin
bronsin's Avatar
Right. I plan to have my son help with that and hope to coach him thru the rest as much as possible. Ive seen pistons that were threaded and had to be turned with a special tool to recess them into the caliper body. It would be good to know about stuff like that beforehand! BUt sounds like its a typical front pad job.
Old 09-03-2009, 08:29 PM   #10
hmmm, if turning my rotors will cost the same as those R1 rotors, you might have another order coming in, Garm.
Old 09-04-2009, 12:21 AM   #11
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Threaded caliper pistons will be found on rear disc brakes, and do require a special tool to retract. The tool is cheap and easy to find, but can be a bit tedious to use. Front brakes on the Camry are a breeze, and should be zero problem as long as you have minimal hand tools. For a car you've never done before, its worthwhile to find a photo DIY online and familiarize yourself with the particular caliper you'll be working on. Also, if you're changing rotors, find out if they are screwed-on to the hub like many Honda's are. I had to get a special-size phillips for my wife's old Accord, but still a breeze.
Old 09-07-2009, 02:15 PM   #12
jonismyname
Drives: 08 liftback 5spd
~$15 each most shops... but thinner rotors warp faster... and those R1's are pretty... pre-painted to look nice behind nice wheels... mmmmm...
jonismyname is offline   Reply With Quote
Old 09-07-2009, 03:47 PM   #13
hahaha. I think I found a shop that does it for around that price, so I'll get them resurfaced first, then, next time around, get the R1's from Garm.
Old 09-07-2009, 06:26 PM   #14
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
I need a pair for my Dodge Caravan tought it was over reacting ABS but its actualy bended rotors!
the_boss is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 06:23 PM
New brake pads and noise eii DIY / Maintenance / Service 8 06-25-2009 11:49 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 05:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 11:21 AM
