![]() ![]() Drives: 07 Yaris S Type Join Date: May 2006
Alarm Install
Here's wiring information for security and remote start. Not all cars are the same, make sure you check every wire with a meter. My car is a 2007 sedan S type bought in Long Beach, CA
12Volts = Yellow(25Amp), Gray(15A), +, Ignition Harness Starter = Black (X2 and are common), +, Ignition Harness Ignition = Pink, +, Ignition Harness Second Ignition = Green, +, Ignition Harness Accessory = White, +, Ignition Harness Keysense = Yellow, -, Ignition Harness (Use this wire to disarm the factory alarm w/o unlocking doors) Power Lock = Brown, -, Driver Kick Power Unlock = Green, -, Driver Kick (Meter wire while turning key in the driver door key cylinder, to Unlock driver door only single pulse, double pulse to unlock all doors) Parking Lights = Green, +, Fuse Box Parking Lights = White, -, By Ignition Harness High Beam = White, -, By Ignition Harness Reverse Light = Red, +, Fuse Box Dome Light = Pink, -, Fuse Box Driver Door = Red, -, Fuse Box Pass Door = Blue, -, Fuse Box Rear Doors = Yellow, -, Fuse Box Trunk Pin = Lt. Blue, -, Fuse Box Park Switch = Black, -, Gear Shift Tachometer = Lt. Green, AC, Data Link Conn. Brake Wire = Green, +, Fuse Box Parking Brake = Yellow, -, Fuse Box Horn = Black, -, By Ignition Harness Speed Sense = Purple, Fuse Box LF Window up/dn = Red / Green, Driver Door RF Window up/dn = White / Pink, Driver Kick LR Window up/dn = Yellow / Black, Driver Kick RR Window up/dn = Red / Green, Driver Kick Last edited by Bones; 06-25-2006 at 11:23 AM. |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 10:15 PM |
| Radio Install Harness and Kit | redbluff | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 08-06-2009 03:40 AM |
| Security / Alarms for the Toyota Yaris | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 31 | 03-29-2007 03:36 PM |
| Does anybody knows how to install the fog lights for the yaris hatchback? | cburac | DIY / Maintenance / Service | 4 | 05-01-2006 01:51 AM |
