![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
Amplifier Remote (turn-on)
hi guys, i tried to connect my amplifier (remote terminal) to PIN 8 (Antenna Power) which is shown in the picture. and yet it only works when i m listening to radio, once i switch my radio to AUX mode thn it will turn off my amplifier again. may i know which pin can i use instead?
thanks for ya helps... |
Unfortunately the power antenna wire is unpowered when playing CDs.
You can use D10 - Pin 3 instead. It is an ACC switched wire, so the amp will be powered even when the radio is not on, but it will turn off with the car. |
thanks,
do u know what color is the ACC switch? other than that is there any pin that i can use so that my amp will turn off when i turn off my player? regards. |
The ACC wire is a gray wire.
On the OEM HU there's no pin that will work for the amp turn on (with both radio and CD) and will kill the amp with the HU. |
thanks CT
does your ACC refer to the Radio Ignition and which is gray in color? |
Yes. ACC is the ignition switched power wire.
thanks for your super fast reply CT,
i tried the ACC wire already and tested with a multimeter. the output voltage of this wire give a voltage of 14V + when my car is ignited. is that alrite to run more than 12V into the Amp? and yet can i actually use the radio battery wire? regards. |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
yes.
and yes.
The 14V into the amp is fine.
The remote turn on is a low power circuit, so using that wire is fine. |
Thank guys....
i have FINALLY done installing my subwoofer and everything works fine. thanks for all the advices. cheers. |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 06:35 PM |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 08:11 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-29-2009 12:53 AM |
| Power door lock keyless entry and remote start | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-20-2009 05:14 PM |
