lily
Drives: white plane jane Join Date: Oct 2009
Winter Tires
Shopping around to buy some winter tires.
I am eyeing the: Firestone Winterforce from Tirerack.com General Altimax Arctic also from Tirerack.com and the: Hankook Winter iPike W409 from Discount Tire Direct. They all range to be about $264-$266 delivered from both sites. I got some 14" steelies and looking at size 175/65/14 for the winter tires. My stocko size is the Potenza RE92 @ 185/60/15. Anyone tired these three tires and have comments on them? Would the 175/65/14 size tires fit my ride? Also, any other suggestions on the tire size? >>> Like a 70 series or an even thinner (165) width tire??? Thank you all!!! |
lily
did another search at this size:
185/70/14 and they were cheaper!!! now... would the 185/70/14 size fit my ride without problems of rubbing and whatever??? *note* I have stock everything so no lowering springs or whatever. thank you. |
I love momentum.
I've run the Firestone Winterforce on my 2WD pickup (New England winters...) and I loved them. So much so that I ordered up a set for my Yaris for this winter. I've run Blizzaks in the past and I'd say the Winterforce work just as well, if not better. They are pretty loud though.
I got a set of 185/60/15's shipped to MA for $260ish. That is before the $25 Amex gift card they send too. |
lily
thanks schleppy,
any other comments on the sizes or tire choices??? |
![]() Drives: 1998 toyota rav4 Join Date: Feb 2009
nokian hakka 5's
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
i myself run the hankook set... went with the 409 because i had a set of the 404 and they never let me down... the 409's are quiet at least for studded tires and have good traction... the only time i got stuck last winter was when the car was pushing snow with my hood so not the tires fault
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
lily
thanks for all the replies so far.
any recommendations on the size??? >>> would the 185/70/14s be OK on my ride??? >>> anyone actually run these same size tires??? just need to know before i dump alot on money and finding out they don't fit or rub like going on a train track. |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
The 175's will work better than the 185's. You want the first number (the width of the tread) as small as possible for winter tires.
And 14's will fit fine, they're what most everyone that gets a seperate set of winter tires for the Yaris runs if they can afford to, from what I've seen. Myself included. I went with Blizzak's since I lack ABS or traction control nd the Blizzak's seem to rate the best for braking and cornering for older non-ABS vehicles.
I LOVE my Yaris!
Drives: 2007 Polar White LB Join Date: Oct 2008
I need snow tires...soon.
We don't see things as THEY are...we see them as WE are. Lisa aka SIPNGAS |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I run the Hankook, but in the 185/60/15 size. No problems last winter except for 1 nasty ice storm. I skidded but was able to steer enough to change lanes and not cause any damage. (to my ride or anyone else's)
Since you have your rims already, you are better off. The problem I had last year was that the steel rims in the packages from Direct or Tirerack kept going out of stock. ~ 10.5K miles on the Hankook with no apparent wear or handling issues |
lily
these are all great info y'alls!!!
i do understand that the skinnier (175s) are better for the snow but then the 185/70/14s costs less...weird. i guess i'm going with the said size above. i'll post back when they are installed and see how i like them. thanks!!! |
My stock sedan size is 185/60/15.
I bought some used 14" steelies with 175/65/14 winter tires from an Echo owner. These 14's are at least 1" shorter (1/2" drop) which isn't working well with my lowered sedan. Snowplow berms where a particular challenge last winter. I plan replace the 175/65/14 winters with 185/70/14 which according to the spec. charts at TireRack.com will be just slightly taller (23.9") than my stock 15" summers (23.7"). This should work well providing added snow clearance to compensate for the TRD suspension.
lily
cool, thanks musk. those are the same size tires i was opting for.
#16 | |
Your car doesn't need to clear the snowdrift, your tires need to stick enough for you to push through. Less than a half-inch won't help, I'd worry more about clearance on your wheel wells for your snow tires, especially with lowered suspension.
#17 | |
![]() ![]() ![]() ![]() Drives: street-legal go-kart Join Date: Oct 2008
ekodrvr
hey toad where was that? we had similar snow drop last winter where i am
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| winter tires | Stiv | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-04-2008 01:57 PM |
| Winter Tires? | sketch182 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 10-23-2008 06:47 PM |
| Winter Tires - For those who lives in Snowy Geography | jmharn | General Yaris / Vitz Discussion | 1 | 10-01-2007 09:36 AM |
